High RPM shifting - please take a look
Old Apr 28, 2002 | 08:18 PM
85_ZED28's Avatar
Car: '85 Z28
98% of the time I drive my car like an old man. I usually shift from 1800 to 2000 rpms. My question is, will shifting the car at around 3000, be hard on the engine? For some reason, I feel guilty when I shift at higher rpms. Does this significantly shorten the life of the engine??
thanks for any info!
Old Apr 28, 2002 | 08:41 PM
Redliner's Avatar
Car: Tahoe
I also have a 5 speed and usaully shift at low rpm's most of the time. I don't think shifting at high rpm's hurt's. I shift at 6000 rpm every now and then.
Old Apr 28, 2002 | 08:45 PM
85_ZED28's Avatar
Car: '85 Z28
6000?
I guess your name is appropriate!
Old Apr 28, 2002 | 09:24 PM
Redliner's Avatar
Car: Tahoe
Well I guess so.
There is nothing better than screaming up to redline as you fly past the girlies in their daddies convertible mustangs.
Old Apr 28, 2002 | 09:54 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
if you're trying to go from slow to fast in a short time you gotta shift high or you'll end up in fourth (auto) or fifth (manual) at 30-35mph instead of 70 or whatever. i've set my redline at 6k, i have a stock bottom end and build top end so i know it'll hold together. my peak hp is at 5k and so i made my shift point 5200 for when i go racing.
Old Apr 28, 2002 | 09:56 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I hope you don't have TPI (stock form), cause you're wasting time shifting that late.
Shifting at 3k is not hard on the engine at all, in fact driving the car like an old lady can be just as bad on an engine.
Old Apr 29, 2002 | 07:53 AM
85_ZED28's Avatar
Car: '85 Z28
how can driving the car like an old lady be hard on the engine??
p.s. thanks for the replies
Old Apr 29, 2002 | 08:13 AM
Car: 99 Formula
Axle/Gears: 342
Because carbon will build up in the engine making it run like crap, check out the post about Pouring Water in the Engine to clean it out posted by Hg.
Old Apr 29, 2002 | 08:52 AM
Z28SpeedKing's Avatar
With my new motor im going to shift at 6500. It should hold up i hope.
Old Apr 29, 2002 | 09:05 AM
85_ZED28's Avatar
Car: '85 Z28
I guess i'm just afraid of blowing a gasket or something
Old Apr 29, 2002 | 09:55 AM
Car: 99 Formula
Axle/Gears: 342
At 3k rpms?? That's nothing, don't worry about that.
Old Apr 29, 2002 | 11:30 AM
Hellraiser's Avatar
Wow, what kind of bottom end/rods are you putting in that thing?
Old Apr 29, 2002 | 12:40 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
My car sees over 5000RPM every single day its out. I have yet to break anything in the bottom end in over 2 years
Old Apr 29, 2002 | 02:04 PM
The crank came out of a pro stock, stock car. My friend had the crank to 7200 with no problems. Im not really shure what it is, and the rods are out of the same car.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
someone972
Aug 30, 2015 12:52 AM
dhonda200
Aug 11, 2015 11:50 PM
