need with with my moms car 91 oldsmobile cutlass
Old May 11, 2002 | 02:21 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
some is rubbing and it sounds like metal to metal right by the serptine belt. do pullys having bearnings that can wear out? anyone ever have a problem where pullys making a scraping sound. I check the belt and it is fine. I listen and it sounds like a pully. any info is appericated.
Old May 11, 2002 | 02:39 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Is it a 3.3?
Old May 11, 2002 | 02:43 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
its a 3.1 and the belts are by the passanger fender
Old May 11, 2002 | 03:23 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Remove the belt and spin each pulley.
Usually its a water pump when its growling at you. They wont always leak when the bearing goes out.
Sometimes the idlers on the tensioner goes, but its usually the WP.
Old May 11, 2002 | 06:17 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
how do fix the idlers on the tenisor if it is them? also when the belt is moving i think it is the tenisor is moving a little bit. is this normal?
Old May 11, 2002 | 06:31 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Yes, the tensioner is suppost to wiggle a little while its running, this keeps the tension on the belt.
Whatever the cause is , (tensioner, water pump, idler) just replce them. There is no way to "fix" them.
Old May 12, 2002 | 04:33 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
so today i went and looked at the car again. the sound is coming from the water pump for sure. so that means it is gonna go soon right?
Old May 12, 2002 | 09:20 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Thats means its gone. Replace it ASAP, dont forget to do the belt/hoses/thermostat to if its been a while.
When they make noise, they sometimes are lose enough to tear up the inside of the timing cover.
Looks like you are WPin soon.
Old May 12, 2002 | 09:21 PM
jdhommert's Avatar
How much HP did the 3.3's have? I thought i read in the manual that it was 90, but that doesn't seem right, it seems like it should be like 150 or so.
Old May 12, 2002 | 09:53 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
my moms is like a fe3 model whatever that means. I would say about 150-160 it gets it ok off the line for a v6 but at 6k it falls flat on its face. just let me say driving that thing then going into the camaro is no comparision. I love my torque the v6 doesn't even know what torque is.
Old May 12, 2002 | 09:54 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
BTW Engineboy i really appericate the help. I can't thank you enough
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
