!!!tta Motor Mounts?!?!?!?!?!
Old May 28, 2002 | 08:20 PM
SheckyZ28's Avatar
I purchase an '89 TTA motor for my '92 Camaro. Im about ready to drop it in, except for the fact that I can't figure out these motor mounts. I have included pictures. I'm thinking he gave me GN motor mounts since they match up with those at a parts store. The TTA ones looks totally different. I also can't figure how these mounting brakets picture mount up to my crossmember. Do I have to drill new holes, or are these even the right ones? Let me know, please. I am ready to get this engine in. Thanks.
http://www.mattsgarage.net/mm1.jpg is the picture of what was sent with the TTA engine.
http://www.mattsgarage.net/mm2.jpg is a picture of the motor mounts and brackets
http://www.mattsgarage.net/mm3.jpg the brackets.
Please help.
Old May 28, 2002 | 08:28 PM
Jester's Avatar
The GN and TTA motor mounts are totally different. the TTA mounts sit the motor lower. I havn't a clue about bolt patterns tho.
Old May 29, 2002 | 02:39 PM
iroc22's Avatar
Are you sure it's actually a TTA motor? Get some head casting #'s and then we can determine whether it's a GN or TTA motor.
Old May 29, 2002 | 04:00 PM
SheckyZ28's Avatar
It has studmounted valve covers. Only the TTA engines had them because the ran different heads.
Old May 29, 2002 | 06:24 PM
poncho9789's Avatar
If I am not mistaken they look somewhat like Oldsmobile motor mounts from a early 80s G body olds with a olds 8cyl engine in it.
Old May 29, 2002 | 10:38 PM
iroc22's Avatar
Actually 89 Buick LeSabre heads to be exact.
Old May 30, 2002 | 08:51 AM
SheckyZ28's Avatar
As far as the heads go, I meant on the 3.8 turbo engine. I know they also came on some BOP FWD cars.
Old May 30, 2002 | 11:46 AM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
Wouldn't it be better to try and figure out the original question then testing everyones knowledge on 3.8 litre engines?
Weather it's a GN motor or a TTA motor, the above is all he has to work with. I don't think it'll work.
Old May 30, 2002 | 01:17 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
u need TTA mounts they ar diff grom reg GN :-) u can get the pass side but u can no longer get a driver side mount at this time so lucky u :-)...Im in the same boat on mine when i pull my engine once i get my formie dialed in....botyh sides are physically the same mount visually but i9nternally are slightly different.....most owners who cannot manage to find a nos set end up running pass side mount on both sides and calling i quits at that , no one that i know of has broken one yet :-)
so ther u go and theres your choices :-)
later
jeremy
PS hit turbobuick.com and go to the tta board supposedly a parts store actual;y carries the correct drvr but i dont know for sure
Old May 30, 2002 | 08:46 PM
SheckyZ28's Avatar
I know about the motor mounts. But what about the motor mount brakets????
Another thing, does anyone know were I can find a diagram of holes cut into an F-body crossmember when swaping in a 3.8 with Grand National motor mounts???
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
