305 tpi cant burn 31 tires with 4.11 gears :( problem?
Old Jun 15, 2002 | 06:08 AM
accentphil's Avatar
i have a 85 S15 with a 305 tpi into it from a GTA
i have 31 tires with 4.11 gears and a 700r4 trans...
if i put the pedal on the floor the tire would not burn just a little..
what can cause that?
the engine is ideling very well.... revving good...
Old Jun 15, 2002 | 07:37 AM
SlowStangEater's Avatar
Re: 305 tpi cant burn 31 tires with 4.11 gears :( problem?
Too much tire....plain and simple
Old Jun 15, 2002 | 11:13 AM
accentphil's Avatar
on jtr manual they show a 350 tpi blazer burning 29 in tires on 4wd...
i cant make smoke my tires even in 2wd...
Old Jun 15, 2002 | 01:32 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
A 31" tire is huge even for 4.11 gears, 4.56 gears are a little better, or 4.88's
Old Jun 15, 2002 | 03:37 PM
Flamingo's Avatar
Car: 89 GTA
Engine: 5.7 TPI
Don't forget, there are 2 sets of gears, the ones in the tranny and the ones in the diffs. What did the tranny come out of and how is it geared?
31s are a lot of tire, and they prolly have some decent tread; they are going to be hard to spin with anything close to stock engine/tranny/gears.
I had an 83 S10 Blazer that I dropped a 327 lightly tricked out and TH350 tranny... talk about a sleeper, I turned many a head with that. I just wish I still had the room so I could work on my IROC, I hate apt living.
Old Jun 15, 2002 | 04:18 PM
NTChrist's Avatar
Yeah, isn't stock like 26.1"?
31", even if its the stock width, will increase the contact patch a lot.
Old Jun 15, 2002 | 05:48 PM
accentphil's Avatar
my Stock Factory Tires are 205 / 75R15...
now i have 255 70R15 ( 31 )
305 Tpi / 700R4 / 4.11 posi
last year i owned a 4.3 Vortec.. and this little engine was so powerful.. more than my actual 305 tpi.. and this 4.3 had only 190 HP / 260 ft/lbs
my 305 is suppozed to have 215HP / 290ft/lbs
so... the 4.3 was 3.42 posi ( 195 75R14... )
and this truck was able to make tires smokin at 20 25 mph... if i put the pedal on the floor...
my 305 isnt able to make it smoke stopped and then after floor it..
the truck is Stock! Engine is also stock...
Old Jun 15, 2002 | 05:50 PM
accentphil's Avatar
http://www.jagsthatrun.com/Pages/Gifs/S10_Truck.jpg
that is a 5spd manual 305 Tpi...
seems to be more powerful than mine ;|
Old Jun 15, 2002 | 06:38 PM
EvilCartman's Avatar
Car: '82 Z28
Problem is still in the size of the tire and the gearing. It's all wrong as it sits now. Also in a truck, there's less weight over the rear tires so it's easy to burn them off.
Old Jun 15, 2002 | 07:54 PM
NTChrist's Avatar
Oh yeah, I didn't notice that you were talking about a S15.
Old Jun 15, 2002 | 08:51 PM
accentphil's Avatar
ive changed my exhaust setup tonight... i went from 1 x 2 1/2 to dual 2inch and the engine is mutch powerful ... i think the catalys were too restrictive... ( that was my cat from my 2.8 )
the mufflers are 2x Walker Pn:18154
i feel the difference... so...
also i have an engine driven cooling fan... i think using a thermostatic fan to replace my flex fan...
how mutch HP my flex fan can use? ( Flex-o-lite Pn:1518 ( 2 1/4 pitch )
Old Jun 16, 2002 | 01:00 AM
Jasper89ROC's Avatar
Try getting a higher stall converter
Old Jun 16, 2002 | 05:49 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
that tire is actually 29" tall
BlueIroc-Z
Jun 9, 2019 03:22 AM
1nastygta
Oct 28, 2015 08:51 PM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
