5 Quarts right??
Old Jul 27, 2002 | 03:16 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
5 Quarts right??
I did an oil change. Drained all the oil out. Put on the new filter and put in 5 quarts of Mobil 1 10w synthetic. If I pull out the dipstick, dry it off, push it all the way down and pull it up, it says im over. Its a decent amout too
Old Jul 27, 2002 | 03:32 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Yep, 5 qts.
Old Jul 27, 2002 | 03:42 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Originally posted by Mark A Shields
Yep, 5 qts.
Isnt it bad to have too much oil?
Old Jul 27, 2002 | 03:49 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
Crank up the engine and let your new oil filter fill up . This may take down the level just a bit.
Old Jul 27, 2002 | 04:07 PM
Car: 99 Formula
Axle/Gears: 342
That's what I was going to say.
Old Jul 27, 2002 | 04:49 PM
Car: 1988 IROC-Z
Engine: 427 SBC
I did the oil change a while ago (not too long ago). Sorry if I sounded like I did it today.
Old Jul 27, 2002 | 07:08 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
5 qts should make it read right at full after eng has been run and shutdown.
Sure it was 5 qts ya put in?
Maybe someone has swapped dipsticks on ya.
Try a dipstick from another Camaro that is known to be accurate.
Old Jul 27, 2002 | 09:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What filter did you use?
If it's the short one (PF25) then 5 quarts may be a little too much; if it's the long one (PF35) then it will take a little more than 5.
EIther way, you're not going to cause any problems. I would guess it's less than a half quart high on the stick, which isn't anything to worry about. A whole quart or more extra would be a bad thing.
And like the other guy said, the dipstick isn't exactly a precision instrument....
Old Jul 27, 2002 | 10:15 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
yep, dump four quarts in the engine. Pour the fith in the filter before install.
Old Jul 27, 2002 | 10:30 PM
breathment's Avatar
mine does that too, its not TOO much above, but its no at the line, maybe half a centimeter above..
atleast u didn't look at ur haynes manual that tells u to use 5.5 quarts.. then it goes really far above
Hotrodboba400
Dec 10, 2019 07:07 PM
abray1
Sep 14, 2015 08:18 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
Navy8125
Aug 17, 2015 01:29 PM
