how to convert a flat tappet motor to a roller motor?
Old Aug 15, 2002 | 10:30 AM
N8Miller's Avatar
got the 350 crate, which is a flat tappet motor (i think) and want to pick up some more horses when we do the cam. now, what all do you need to switch over to a roller motor. obviously a roller cam and lifters, but anything else?
thanks guys
Old Aug 15, 2002 | 10:42 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
cam button, correct length push rods
Old Aug 15, 2002 | 10:49 AM
ede's Avatar
ede
since rb never said it i'll ad like we've been doing since the 60s. might want a bronze distributor gear too, depending on what you end up with.
Old Aug 15, 2002 | 11:28 AM
Todds1987iroc's Avatar
I think you will have to get aftermarket roller lifters. The factory ones were desiged to only work in a "roller" block. This block had provisions for roller lifters in that the lifter bore height was different so the lifter holders could be installed. These holders keep the lifters from turning in their bores and were held in place with a spider as some people call it. This sprider bolts to the block in the lifter valley. Non roller blocks do not have the provisions to mount this spider except some early '86 blocks. Remember GM went to roller cams in late '86 and all of '87 and up V8 cars. Some trucks did not get roller cams until the mid 90's.
New GM crate motors should have roller cams already from all of the ones I looked at.
Old Aug 15, 2002 | 12:29 PM
felo72's Avatar
Todds right, but Crane and Comp make a retro fit hydraulic roller setup. If you planned on buying a stock GM or any regular roller cam and lifter set they wouldn't work. Everyone else is right on with the other accesories, but remember to ask for the retro fit cam and lifters. If the block is not a flat tappet block and a roller block, then don't listen to me.
Old Aug 16, 2002 | 06:36 PM
zroc's Avatar
Car: 87 IROC
Engine: LB9 for the moment
anyone ever heard that the lifter bores are not in the same alignment as the roller blocks???
zroc
Old Aug 16, 2002 | 07:03 PM
alohamike's Avatar
may want to check the GMPP listings. They make a conversion kit that includes all the parts and the ZZ4 cam (I believe).
Old Aug 16, 2002 | 07:40 PM
alohamike's Avatar
guess I spoke too soon. went to the gmpp site and didn't find what i thought i saw previously. sorry
beastin91rs
Oct 9, 2015 07:38 AM
camaro71633
Sep 1, 2015 10:24 AM
Dialed_In
Aug 20, 2015 01:45 PM
anesthes
Aug 8, 2015 09:37 PM
