Which kind of cam is better?
Old Sep 17, 2002 | 10:28 AM
twiztidz28's Avatar
Car: 86 Z28
Engine: 355 carbed
Transmission: t-5
I am going to be doing a heads and cam swap on my car in the next month or 2 and was wondering how hard it is to change the cam. What is the difference between the Hydrolic ller and Regular Hydrolic cams? Which type is better? Any help would be great I was looking at Comp Cams .477"/.480" with a 268 grind, rpm range: 1600-5800
Old Sep 17, 2002 | 10:36 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
A hydraulic roller will be better as there is less friction = more HP. I'm not sure if it will slide right in though, without some mods, I'll let someone else answer that.
If you're changing heads, changing a cam at the same time will be a lot easier.
Old Sep 17, 2002 | 11:11 AM
ede's Avatar
ede
a roller is better all the way around, it'll be smoother and still have more aggresive profile than a flat hydrolic. if you can use one depends on the block you have, since you never said. if it's not made for a factory hydrolic rooller you can't run one, without lot of work. easier to find another block.
Old Sep 17, 2002 | 11:15 AM
twiztidz28's Avatar
Car: 86 Z28
Engine: 355 carbed
Transmission: t-5
Well I have a 350 block. if that helps. So a roller cam would be better then jsut the hydrolic?
Old Sep 17, 2002 | 12:22 PM
ede's Avatar
ede
not all SBCs are the same. you need a SBC made for a roller or you can't use a factory hydrolic, but you can run an afteramrket roller in any block.
Old Sep 17, 2002 | 01:06 PM
twiztidz28's Avatar
Car: 86 Z28
Engine: 355 carbed
Transmission: t-5
So that comp cam sounds pretty good then it is a roller?
Old Sep 17, 2002 | 01:13 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Those specs look like a XE268.
If so, then no, it is not a roller cam.
Old Sep 17, 2002 | 01:51 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
A little more explanation. You make more power by getting more air in and out of the combustion chamber. The cam's job is to open the valves to allow this to happen. With a cam, your choices for getting more air in and out include opening the valve higher, opening it longer, and opening it faster, holding it open at its maximum position longer, then shutting it faster. The last option is generally the best, because the other two will create more overlap (having intake and exhaust valve open together). The problem is, you can only make a hydraulic cam so steep before the lifter won't be able to ride up it smoothly, and it will put severe stress on the lifter, rocker & spring. With a roller cam, you're dealing with a round lobe instead of a flat one, and this allows you to provide a much steeper profile on the cam, i.e. open and close the cam much faster.
The benefit to roller cams is due mostly to the better profiles you can run, and not so much the reduced friction.
Old Sep 17, 2002 | 02:24 PM
Bort62's Avatar
Old Sep 17, 2002 | 04:52 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Ahhh....
Another thirdgen Juggalo!
-Rich-
Old Sep 17, 2002 | 07:49 PM
SinthetikIroc's Avatar
Car: Corvette
Engine: 5.7
Originally posted by RICH92RS350
Ahhh....
-Rich-
lol
Old Sep 17, 2002 | 10:20 PM
RICHRAD's Avatar
It is understandable that the air must enter and exit the cylinder rapidly, but I always understood cam functions as allowing more fuel mixture to be brought into the cylinder. Have I misunderstood all these years
Old Sep 18, 2002 | 07:19 AM
twiztidz28's Avatar
Car: 86 Z28
Engine: 355 carbed
Transmission: t-5
Ahhh....
-Rich-
Hell Yea
Old Sep 18, 2002 | 12:41 PM
Jim85IROC's Avatar
only by the fact that the fuel is mixed with the air. On a carbed motor, the fuel gets mixed with the air way up in the carb and is brought into the combustion chamber along with the air.
On a port-injected car, the fuel is fired directly into the intake runner of the head, so the air has less work to do in order to bring it into the combustion chamber, but it's still more or less the same situation.
Old Sep 18, 2002 | 12:59 PM
twiztidz28's Avatar
Car: 86 Z28
Engine: 355 carbed
Transmission: t-5
So even though my car is Carbed i could still go with a roller cam? Is taht a good choice. I want power to around 5500 RPM
Old Sep 18, 2002 | 01:03 PM
Car: 99 Formula
Axle/Gears: 342
A roller cam will also be about 2x the price, unless that doesn't matter.
The Comp 268XE makes power to what you want, just to let you know.
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
masonta
Sep 1, 2015 06:40 PM
