Anybody Have a formula to figure the lift a 1.6 rocker will add?
Old Sep 25, 2002 | 11:20 AM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
That is my question. I have 1.5's and have a cam that has .480/.480 lift. What will 1.6 rockers bring my lift to and how do you come up with it? I'm sure alot of people can use this. Thanks
Old Sep 25, 2002 | 11:29 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Divide by your current ratio and multiply by the new ratio. You'll be at .512.
Old Sep 25, 2002 | 01:30 PM
cool, thanks.
(cam lift / stock rocker ratio) x aftermarket rocker ratio = total lift
example (.480 / 1.5) x 1.6 = .512
This should be put in the equations list, since more and more people are going to higher ratio rockers without changing valve springs.
Old Sep 25, 2002 | 03:52 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Maybe it could be in the equations list, but no offense or anything but it's basic arithmetic.
Old Sep 25, 2002 | 04:20 PM
Yes it is basic math once you know what to do with the numbers. I spent a good five minutes trying to figure it out and gave up, so I asked. I'm sure there are alot of people who feel confident in their arithmatic without having a second opinion, I however am not one of them. On the other hand, some people don't even know how to figure out the radius of their tires, so our site instructs them to do so. Wouldn't it be nice to give a formula to those who aren't sure of themselves, so them they can understand how they got their answer? But thanks alot or the help, I'm glad I understand now how to calculate total lift.
Old Sep 25, 2002 | 09:01 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Here is another way.
Simply multiply the gross lift @1.5rr by 1.0666
This will give you the new lift with a 1.6rr
.480" X 1.0666 = .512"
Old Sep 27, 2002 | 11:37 AM
cort351w's Avatar
Damn, man--I had to make it into a first-order linear ODE system and use Laplace transform.
Old Sep 28, 2002 | 06:45 AM
Vader's Avatar
The third worksheet on this spreadsheet gives lift, duration, timing, and acceleration rates of the valves with varying rocker ratios:
Engine Calculator.xls
midge54
Dec 27, 2019 04:14 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
Cameeeero
Sep 18, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
happyhapka
Aug 15, 2015 04:42 PM
