Valve cover change
Old Sep 26, 2002 | 01:26 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
Valve cover change
Hello i just bought these chrome valve covers and im going to replace the old ones with these. The problem (shame on me) is that i dont know really how to do it. So i ask you guys if you know what to do and not do. I also bought new gaskets because i guess that the old ones are not so good to use again.
Old Sep 26, 2002 | 01:47 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
by the look of those covers u bought centerbolts so make sure that the ones u are using on the motor now are centerbolts. if so there should be 4 in the center of your old valve covers. take the two hoses/grommet/breathers off and put on your new ones with those same four bolts. if u dont have four bolts along the center of your old covers either return the covers u bought or buy 4bolt cover conversion kit form summit or i even think jegs sells em
Old Sep 26, 2002 | 04:06 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Ok thank you. Yes its a tpi engine so it has centerbolts Do i need to remove something on the passenger side? Theres a lot of hoses and stuff running there.
Old Sep 26, 2002 | 05:37 PM
irocbsa's Avatar
I've done it so much now that I can get the passenger one on by just routing it properly under the hoses. Of course I removed all the AIR pump stuff so that's not in the way anymore. If yours is still there you'll probably have to take it off. (Its a black box with a bunch of hoses coming off of it) If you don't have emissions inspecitons where you live you should just leave all of it off. No point to it really.
Also, when you do the passenger's side be careful of the alternator power cable. Nice big spark if you hit it with the cover.
Old Sep 27, 2002 | 12:06 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
ok thank you. Well i dont have to use a cat on my car so why keep the air pump, i have already removed some of the stuff when i changed to heeders. They only check the CO level . I think it has to be under 3.0 or maybe 4.0 so its not too hard to pass.
Old Sep 27, 2002 | 01:25 PM
BAK12484's Avatar
mind if i ask where you picked those up?? i've been looking for some good centerbolts for a while
Old Sep 27, 2002 | 01:46 PM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
Yeah, I love it when my passenger side valve cover sparked, took a second to figure out what was going on, lol.
Old Sep 27, 2002 | 02:03 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
I found these at Summitracing.com. The part number is PRO-141-107. They cost about 106 dollars.
I think they look pretty good and they are not too expensive.
MoJoe
Sep 24, 2015 09:12 PM
NBrehm
Aug 25, 2015 11:49 PM
g.l.mos
Aug 22, 2015 12:02 AM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
