Best Engine for 88 TA GTA
Old Oct 3, 2002 | 03:20 PM
Bradleyscott's Avatar
I am working on an 88 TA GTA (t-tops) and would like to get a feel for what the best engine transmission combination would be. I am about a month or two away from getting to the point were I will be getting a new engine and tranny to install.
Two points I am looking for, Best combination for the buck, and just best overall combination without regard to money. I haven't decided if I am ready to go all out or if I want to save that extra money for another project car.
Thanks Brad
Old Oct 3, 2002 | 04:02 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
ZZ4 crate and T56 would be a great bang for the buck.
Old Oct 3, 2002 | 09:41 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
Well do you have to pass smog? That will play a roll in the decision of an engine. T-56 is a the tranny I would get though. The ZZ4 is awesome but not smog compliant.
Old Oct 4, 2002 | 01:54 AM
Sauron91's Avatar
Be sure to do some suspension mods..
Old Oct 4, 2002 | 09:40 AM
Car: 99 Formula
Axle/Gears: 342
ha, you cheated your post count, and I'm still beating yuo, guess till you see thiss.
Old Oct 4, 2002 | 10:21 AM
ede's Avatar
ede
it'd help if you said what you're wanting to do, plus the e check thing, and how you define best
Old Oct 4, 2002 | 06:31 PM
I am restoring the car, not to original specs, but just to be more sound, more horse, a better engine than you could really get back in 88. Same with the Tranny, I want a combination that will work together well, without many modifications having to be done. So the more horse I can get out of it without adding a lot of nitrous, etc. The better.
Right now, I have done the work on the chassis and it is in the garage with nothing attatched to it. The rest of the car is in the other car bay in pieces and I have been replacing old worn out parts, cleaning the ones that still have a life span left in them and am about a month away from being ready to place the engine and transmission on the chassis. I plan on just getting both new and would like to put the best engine (that is compatible) in the car, I don't want to do many modifocations to get it to work.
And I have no Smog requirements
Old Oct 4, 2002 | 08:22 PM
trans87's Avatar
I would suggest then the ZZ4 if smog isn't involved. It is an awesome motor just waiting to shake more hp out of the already 350hp:hail: As for a tranny I really like the T56. It can handle a lot of power and is strong.
The_Phoenix
Feb 4, 2016 07:10 AM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
Street Lethal
Aug 14, 2015 08:25 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
