Car has mind of it own~??
OK heres the deal.........I replaced my battery about a month ago, my alternator 2 weeks and my starter 2 weeks....Ok now when i try to start my car only every once in a while she just doesnt want to turn over, give a clicking noise or anything but if you leave her alone for about 15 min she will then turn over SOME ONE PLEASE HELP!!!!
Car: 99 Formula
Axle/Gears: 342
I'm a bit confused by the wording at one point. You saying sometimes it does absolutely nothing?
do you have power to the lights at all when this happens? if not check the ground to the battery.
Car: 1986 Pontiac Trans Am
Engine: 305 LG4
Transmission: Borg Warner 5 Speed
try adjusting the ignition switch, my friends car wouldn't start sometimes and sometimes it would, we replaced the switch and BOOM, starts everytime.
Car: "02 z-28
Engine: LS-1
Originally posted by rezinn
Is this when you're trying to start it hot? If so, it may be a heat soak problem with your starter solenoid.
Linson
Aug 21, 2015 02:12 PM
kah992
Aug 19, 2015 02:55 PM
