Old Nov 21, 2002 | 08:17 AM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
serpentine help
how do you remove a serpentine belt? what does the tensioner look like?
Old Nov 21, 2002 | 10:18 AM
ede's Avatar
ede
idler pulley lookign thing mounted on an arm, not a drive pulley to an accessory. has a 13mm or 15mm hex or maybe used a 1/2" breaker bar to move it
Old Nov 21, 2002 | 10:32 AM
MdFormula350's Avatar
the tensioner is where the idler pulley is.. is up high on the engine acessories.. i usually take a racket and stick it in hole then press down to pull the idler puller high enough to get the belt to come off, it takes 2 minutes to change a belt, just make sure you follow the right path of the belt..
good luck
Old Nov 21, 2002 | 10:40 AM
Vader's Avatar
It's at the top of this photo:
Old Nov 21, 2002 | 10:58 AM
Jza's Avatar
Jza
Hm, that's an interesting pic. I don't like that routing very much, since the ribs will ride on the idler. Is the spring reversed?
Kinda cool that the alternator is in the smog pump position; I'm assuming to make room for a turbo or two.
Old Nov 21, 2002 | 01:38 PM
Vader's Avatar
I'm not sure about the idler rotation. That was an early attempt by Jester to reroute his belt on his twin-turbo setup. You'd have to ask him how the final assembly was done.
Old Nov 21, 2002 | 02:13 PM
rezinn's Avatar
Here is a pic iroczrockz posted yesterday, it shows his routing to bypass the smog pump and compressor, and in the lower left hand corner is a diagram of the real routing. The tensioner is centered in the pic.
Old Nov 21, 2002 | 04:15 PM
breathment's Avatar
hmm do u know what size belt is needed for that? and what the belt routing is for that? i think im gonna do that..
hmm i just noticed that the ribs of the belt are on the tensioner pully. that shouldn't hurt it right?
Old Nov 21, 2002 | 04:25 PM
breathment's Avatar
ahh. hmm never mind.. i found it.. https://www.thirdgen.org/techbb2/sho...hreadid=144127
Pac J
May 17, 2020 10:44 AM
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
383backinblack
Oct 14, 2015 08:50 PM
gta892000
Sep 16, 2015 12:40 AM
