when cold-won't run good
Old Nov 10, 2002 | 10:51 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Anyone have the same problem? When my car is cold, it starts fine and idles fine but when you put it in gear it dosen't want to go. It acts like it is not getting any gas at all. I just swapped out the motor from a 305 to a 350 and I put a new TBI unit on from Turbo City and new injectors and the problem is still there. When the car warms up the problem goes away. The air/fuel gauge shows lean mixture when that happens. Any ideas????
Old Nov 11, 2002 | 09:03 AM
Vader's Avatar
Have you checked fuel pressure?
Old Nov 11, 2002 | 02:42 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Fuel pressure stays at 12psi. dosen't waver. I was beginning to think that it might be the fuel pump because that is the only thing that is original, but like I said the fuel pressure stays the same.
Old Nov 11, 2002 | 09:17 PM
Vader's Avatar
Pressure should be perfect, since the allowavle range is 11-13 PSIG.
Any more details or hints?
Old Nov 12, 2002 | 02:52 AM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Timing is dead on, could it be the fuel filter? That don't make sense about it being warm though and working fine. Could it be a sensor of some kind? It worked fine right after I put on the new TBI and injectors and then a couple of days later it started doing it again but not as bad before with the 305 TBI. Could this be the chip doing this? I need to get a custom chip made!
Old Nov 12, 2002 | 03:09 AM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
your car has gremlins
Old Nov 12, 2002 | 07:43 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
probably just what you said in your post about the auto meter. Its going lean in open loop because the ecm is going right off the VE tables for the ol' 305 and isnt supplying engough fuel. When it goes into closed loop, the ecm can now see the engine is lean throught eh o2 sensor and can correct, within limits, for the lack of fuel. You need to burn a prom for it.
Old Nov 13, 2002 | 08:21 AM
Vader's Avatar
Your original post stated "new injectors", but what size? 36lb?
Old Nov 27, 2002 | 04:13 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Sorry that took so long they are 61# injectors.
specialized
Jun 18, 2022 09:26 AM
InfinityShade
Aug 22, 2015 08:00 PM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
squiggy2
Aug 9, 2015 09:30 PM
