Distributor Clearance with new Edelbrock intake
Old Nov 21, 2002 | 01:38 PM
(BR)G-Machine's Avatar
I instaled an EGR intake on the Camaro and now it leaves about at 1/4 inch gap between the distibutor to the intake when the gear is fully engaged to the oil pump. I havent played with it too much put it seems that the facing for the distributor to manifold is lower on the Edelbrock intake rather than the stock cast iron one (Yes, iron cause the car is Canadian.
It was an interferance installation... the pre 87 one on the 87 heads... but other than this and the redrilling of the 4 intake bolts there was no other issues.
What's up with this? Anyone else get that?
I would like to put my money into a few other places before a pricey aftermarket distributor... are there any spacers or seals I am missing?
Ty for any help...
Old Nov 22, 2002 | 02:56 PM
So is the only remedy a splip collar distributor?
Old Nov 22, 2002 | 03:16 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds to me like the dist isn't on the oil pump properly, even though maybe you think it is. There are no other possibilities.
Never heard of a splip-collar distributor, it's never really necessary because there's so much tolerance at the oil pump drive when everything is assembled correctly.
Old Nov 22, 2002 | 03:48 PM
gruveb's Avatar
Car: 1989 IROC-1
Ditto:
You've got the distributor in backwards.
Old Nov 22, 2002 | 04:59 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Yeah the oil pump drive probably isn't lined up.
Old Nov 22, 2002 | 05:09 PM
KK... ya you are probably right. I think that I must have bumped over the engine or something with I was installing other stuff and screwed up my pic of the rotor position.
Ty guys and I will keep ya posted.
Old Nov 22, 2002 | 05:27 PM
gruveb's Avatar
Car: 1989 IROC-1
You know how to fix it?
I don't know much, but i know my way out of that one..........I always get laid on bottom because it seems like I can only screw up!!!!!!!!
Anyhow, if you need to know how to get everything back on line so you can drop it in correctly, speak up.
Old Nov 22, 2002 | 05:28 PM
Yep... slipped right in one way... is this the only way it will go in is (basically) the right way? I know I will have to set the timing but it's fire on the right cylinger right?
Old Nov 22, 2002 | 08:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
As long as the rotor points to the right cylinder at the right time, you can put it in any way it fits.
Old Nov 23, 2002 | 01:29 AM
TBI305Camaro's Avatar
The distributer may be a tight fit like mine was....took some work to get it down in the brand new motor but it went.
It will only go in 2 ways so keep trying.
Old Nov 23, 2002 | 02:22 AM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
You can take a long screw driver and turn the oil pump so that you can line it up to #1. The distributor only fits in 2 ways 1) the right way 2) 180 degrees out <--- the wrong way. It really doesn't matter though. As long as the rotor is pointing at the number 1 plug then its fine. You'll just have to shift the firing order over. Remember that from the right just before the box (that includes the wire for the tach and the rest) the order going clockwise is 2-1-8-4-3-6-5-7.
Good luck,
Brian
Old Nov 24, 2002 | 01:44 PM
TY for your help...
beastin91rs
Oct 9, 2015 07:38 AM
DJanes97
Sep 1, 2015 02:55 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
86IROC112
Aug 17, 2015 02:00 PM
Out-Cast
Aug 17, 2015 10:57 AM
