350 Buildup Options What Do You Think?
Old Dec 25, 2002 | 08:30 AM
FactoryFreak's Avatar
Car: 1988 GTA
Transmission: TH350
Alright i need some help building my engine. I want it to be a 355 that going to be able to handle a TNT nitrous wet kit 150-200hp kit. I want the engine to push around 350-400hp without the nitrous. This is going in an 88 GTA. Heres my thoughts so far.
AFR 190cc or 195cc heads
Holley Stealth Ram Intake
Comp. Xtreme Energy Cam 276/281 224/230 .503/.510 112LS
Comp Cam Pro Magnum 1.6 roller rockers
SLP 1 3/4" Headers
3" Cut-Out
3" Flowmaster Exhaust
52mm Holley Throttle Body
Custom Cold Air Intake
B&M 2400 Holeshot Torque Converter
3.70 gears (9 bolt)
Spohn suspension ( torque arm, LCA, LCA relocation brackets, and panhard bar)
I'd like to here your comments on this setup.
I also would like to here some suggestions on building the bottom end of the engine.
Also if 400hp is possible with this setup:lala:
Old Dec 25, 2002 | 02:04 PM
ohyeahjay's Avatar
all arp bolts/ fasteners/main studs after market main caps and crank just to be sure. A good ignition system and make sure you run colder plugs and a more rich air/fuel ratio. Good fuel with octane boost as well. The slp headers are not long tubes are they, if not maybe go with the hooker 1 3/4 long tubes to give you more bottom end tork. Just my 2 cents.
Old Dec 25, 2002 | 09:36 PM
MdFormula350's Avatar
sounds like a pretty good setup!!
Old Dec 25, 2002 | 11:37 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'd go with the Hooker cat-back, my personal taste, sound clip in sig.
I think for what that motor is costing, which won't be cheap, why skimp and get the B&M converter?? they're not the best, plus that is kind of a low stall, you could benefit from a higher one.
Old Dec 26, 2002 | 03:07 AM
85TPI400's Avatar
Looks like around 400hp (flywheel). If you are going to give it a 200 shot of nitrous, I would invest in a forged rotating assy!
Old Dec 26, 2002 | 08:17 AM
Car: 1988 GTA
Transmission: TH350
Yeah I was also thinking of going with a Viglante converter.
I planned on having all the internals forged, but what would you recommend for pistons, and rods and such?
Old Dec 26, 2002 | 09:28 AM
ede's Avatar
ede
lunati crank and rods and j&e, c&a, or ross pistons, i'd run dished. better look into springs, rockers, and good studs for the heads. might want to consider spalyed mains
Old Dec 26, 2002 | 01:19 PM
87TA 305TPI's Avatar
i say go with the GM forged crank, its a good crank and its cheaper than any of those other aftermarket cranks, keep GM cars all GM...
Old Dec 26, 2002 | 01:43 PM
Hung Start67's Avatar
What to choose.
Everything you have picked out sounds great. The 3.70 gears might be a touch deep. They will work yes..But you need to ask yourself is this car going to be a daily driver? If it is going to be a daily driver I would suggest a 3.42 or a ratio close to that..I own a 92 z stock with 700R4 and 3.23 gears and the deepest I would go is 3.42 just to many revs with anything deeper. Enjoy that ride...Later...
Old Dec 26, 2002 | 04:29 PM
Car: 1988 GTA
Transmission: TH350
Yeah I wasn't quite sure on the gear ratio yet but it will be for the street and strip, mainly the strip though. I'll probably drive it around town some on the weekends but not very much. :hail:
Old Dec 26, 2002 | 07:47 PM
Mainly strip/street car 3.70 will work just fine..If you wanted a mainly street/strip I would go with a 3.42 or around that. Have fun..
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
RedLeader289
Jan 22, 2016 03:05 PM
Eric-86sc
Aug 24, 2015 09:01 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
