Car revs when at a stop
Old Dec 31, 2002 | 04:51 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Okay, heres my problem-
When I'm at a stop, the RPMs will go from 300-600 until I get going. When I let off the brake and give it gas, it kinda stutters until the RPMs go about 1500, then it goes no problem. I just replaced the cap, rotor, plugs, and wires. Any ideas what the problem is? Thanks in advance.
Old Dec 31, 2002 | 05:09 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Fuel filter maybe??
Old Dec 31, 2002 | 05:10 PM
Enkil's Avatar
Could be that the IAC/TPS needs to be checked/adusted. RPM's should never go that low. If you're not sure how to do it, https://www.thirdgen.org/newdesign/tech/tpimod2.shtml
Old Dec 31, 2002 | 05:31 PM
Car: 1989 IROC-Z
Engine: 383 stroker
In the article, it says to put a paper clip in the a and b terminals.. which ones are those?
Old Dec 31, 2002 | 05:49 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Just take out the arrows.
Old Jan 1, 2003 | 04:04 PM
Car: 1989 IROC-Z
Engine: 383 stroker
Update- I replaced the fuel filter and took it for a drive. When at a light, it no longer varies the RPMs, but then when I go, it almost stalls and I hear a noise that sounds kinda like a backfire. Any other ideas before I just take the damn thing to the shop?
Old Jan 1, 2003 | 04:19 PM
Car: 1988 IROC-Z
Engine: 427 SBC
burn off relay?
How olds your 02 sensor??
Just tryin to shoot some ideas at you.
Old Jan 1, 2003 | 05:48 PM
Car: 1989 IROC-Z
Engine: 383 stroker
o2 sensor isn't too old, I dunno about the burn off relay.
Old Jan 1, 2003 | 10:27 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Andy, my Blazer did that same thing for awhile. And it was brand new. I had to replace some of the injectors-under warrenty thank ***. Once the injectors were replaced no more problems. Put the car on a computer before you shell out the dough. Pep Boys on La Grange will check it for free. The one by my house in Homewood will do the same. No strings.
Now you know why I like my carbed engine. Easy to fix.
Old Jan 2, 2003 | 04:26 PM
Thirdgen86TA's Avatar
Check for the MAF sensor. Mine kind of does the same thing. Check for codes too.
Old Jan 2, 2003 | 05:10 PM
Car: 1989 IROC-Z
Engine: 383 stroker
I had a TPS laying around for my LT1 intake so I put it on, no luck. I also have a MAF, so I'm gonna go try that too.
Old Jan 2, 2003 | 05:39 PM
Car: 1989 IROC-Z
Engine: 383 stroker
Well I put on the new MAF and things have improved greatly.
On the way home from work the car almost died 5 times. After installing the MAF, I took it for a test drive around the block. It still hesitates slightly and is a little sluggish to get going up hill, but it isn't even close to stalling now.
Old Jan 2, 2003 | 05:45 PM
Thats great to hear. Did you just have a new MAF laying around or something? Im not an expert but it could be relearning all the info from the new MAF.
Old Jan 2, 2003 | 07:12 PM
Car: 1989 IROC-Z
Engine: 383 stroker
I recently bought an LT1 intake that came with a MAF, so I used that one.
I just drove it for a while and its idling at about 1500 now and the SES light is on.
Ghettobird52
Jul 5, 2024 11:18 PM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Sherpajames
Aug 7, 2015 06:56 PM
