Post pics of your *stock* TPI motor
Old Jan 28, 2003 | 06:36 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
I'm in the process of cleaning up my engine bay. A previous owner swapped a 350 into my car, and they didn't do the best job of tucking stuff away and making it look factory original. I need any pictures of the stock TPI engines, 305 or 350 (they're pretty much the same with wiring, etc). Close-ups of the various areas, such as valve covers, distributor, and inner fenders would be great. Also, I'd like some pictures of the labels that appear under the hood and on the fan shroud.
Old Jan 28, 2003 | 06:48 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Well mines not a stock motor but I did run everything in stock locations. Except for my MSD spark plug wires. I routed those while the engine was on the motor stand, they go behind each cylinder head and then underneath my headers.
Hope these help...
Old Jan 28, 2003 | 07:30 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Hey TunedPort335......I love where u mounted your MSD Ignition box.....do you have any pictures of how you mounted it....or could you tell me how you mounted? It's kind of hard to tell in the pictures. I just bought an MSD-6A Box for my 91 Z28....your box looks really unifrom...like it's not stuck in a corner or anything.
Old Jan 28, 2003 | 08:41 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Old Jan 28, 2003 | 08:53 PM
Hey thanks for the comment man.
I took a peice of steel, a little longer and wider than the MSD 6AL itself. I then bent up one end of the steel (facing the drivers side of the car), and drilled a couple holes into it. I mounted it to the fender using a couple self tapping screws. As you can see, I mounted it above the vacuum canister thing (or whatever that emissions crap is underneath it)
I can't explain it really good and I sound like a retard but Oh well. I hope you know what I mean.
I then mounted it to the plate of steel using the hardware that came with the 6AL. Easy as pie. I didn't want to mount it to my shock tower like most people do, it looked sort of "crammed" in there.
Heres some more pix
Old Jan 28, 2003 | 09:10 PM
Engine: 5.7
Well...it does really look good....and I think I know what your talking about on how to construct a bracket to mount it. A guy could probably even mount it above that battery too..don't you think? Just make the same bracket and everything....
Old Jan 28, 2003 | 09:54 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
IROCThe5.7L, clean engine bay, not too fond of all the stuff but very clean...
Old Jan 28, 2003 | 10:51 PM
gtaguy87's Avatar
Car: 1998 Ram Air Trans am
Engine: Ls1
Transmission: 6 speed manual
MSD Ignition
I like where you mounted that ignition too the only thing is my battery is right there, can you still get to your battery, also I have an MSD Ignition 6a and i have the MSD two tower coil, is there some kind of adapter i need to get so the ignition will hook up to the coil, thanks for the help
Old Jan 28, 2003 | 11:31 PM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
Here's mine
Old Jan 28, 2003 | 11:32 PM
Old Jan 29, 2003 | 08:32 AM
blue86iroc's Avatar
Car: 1986 IROC-Z
Great stuff so far, everyone. This is really going to help me out. I'd like some close-up shots, too, so I can see how the hoses and wire loom is laid out -- a few detailed pictures of the firewall would be good, too. Does anyone have some pics like that?
Old Jan 29, 2003 | 01:15 PM
H0TR0Dn's Avatar
Car: 88 Formula 350
here's mine
Old Jan 29, 2003 | 01:39 PM
H0TR0Dn's Avatar
Car: 88 Formula 350
drivers side
Old Jan 29, 2003 | 01:42 PM
H0TR0Dn's Avatar
Car: 88 Formula 350
passenger
Old Jan 29, 2003 | 01:46 PM
H0TR0Dn's Avatar
Car: 88 Formula 350
My plug wire setup is temp. till I find a setup I like.
Old Jan 29, 2003 | 02:21 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
All the "stuff" is stock.
Old Jan 29, 2003 | 03:06 PM
Re: MSD Ignition
My battery is on the passenger side of my car.
Maybe it's on the other side on the firebirds??
Old Jan 29, 2003 | 03:47 PM
Jim85IROC's Avatar
MPFI/TPI Firebirds have the battery on the driver side and the airbox on the passenger side. I have no idea where the tbi/carb firebirds have the battery.
Old Jan 29, 2003 | 05:39 PM
87kevroc's Avatar
Car: 1987 Chevrolet Camaro Z28 IROC-Z
Transmission: TeamTripp Performance
Not super clean, but shows some detail-
Old Jan 29, 2003 | 06:07 PM
Rob116's Avatar
Car: 1986 Z-28 Camaro
Engine: 355
Good lord you guys with A/C and emissions must have fun changing plugs on that passenger side I'm guessing that most of you have to jack the car up to get at some of them...?
Old Jan 29, 2003 | 06:34 PM
Vader's Avatar
The labels you'll need look like this:
Old Jan 29, 2003 | 06:59 PM
You got it!!
Takes me around 15 minutes or so.
Old Jan 29, 2003 | 07:03 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
Wow, I really appreciate all of the pictures that everyone is providing for me. Vader, you're the man -- those labels are great!
Yesterday and today I've been tearing into the wiring for the engine systems... fuel injection doesn't seem so complicated now . The previous owner did a wonderful job of making sure that all of the wires were properly connected when they swapped engines. I'm so fond of twisted wire with electrical tape covering it up . You should've seen the fuel injector wires; those were pretty bad too.
If anyone's interested, here are two pictures of how I'm coming along. The first one is after I cleaned up the heater/AC wiring, and the second is a general shot of the passenger side of the motor. I think the engine compartment is going to look a hundred times better once I'm all done.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Linson
Aug 21, 2015 02:12 PM
st.evel07
Aug 13, 2015 06:15 PM
marcusaw
Aug 10, 2015 08:13 AM
squiggy2
Aug 9, 2015 09:30 PM
