Can a bad PCM cause the fuel pump not to work and no spark? (attn. Vader)
Old Feb 4, 2003 | 06:02 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I am working on a 1993 eagle talon 1.8 and can't get the thing to start. Some of you guys helped me with this last week. The fuel pump doesn't seem to be kicking on and there is no spark coming from the distributor. I am beginning to think that the PCM is causing this. I have replaced the fuel pump and distributor. On these cars you can't just replace the ignition module or coil seperately. You have to replace all of it.
Old Feb 6, 2003 | 12:36 PM
Morley's Avatar
Don't know if the PCM would control the fuel pump, I would doubt it. Does the car have a relay for the pump? Every FI car I've owned does the same "prime" routine when the key is turned on.
You replaced the dist. and still get no spark? U'd say that the hot wire goint to it is broken somwhere, or the ignition switch isn't working properly.
But then again I have no experiance with eagles, so take it for what its worth.
Old Feb 6, 2003 | 12:42 PM
Morley's Avatar
stupid double posts.
Old Feb 6, 2003 | 05:39 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Do any of you guys know the name of the sensor that shuts the fuel system off if it's been in a collision? I have heard the name of this before but can't think of it.
Old Feb 6, 2003 | 07:43 PM
Morley's Avatar
Inertia switch, maybe?
Old Feb 6, 2003 | 09:08 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
I think that is what it is. I have heard of ppl manually flipping the inerta switch to mess with some one's car. I think you have to hit it with a hammer or something though to flip it.
Old Feb 6, 2003 | 09:25 PM
Morley's Avatar
Yeah, they hide them in the trunk or somewhere out of the way too, they usually have a manual reset on them or very near by.
Old Feb 6, 2003 | 09:52 PM
Vader's Avatar
Ford uses the fuel pump cutoff switch. It is a manual reset. I'm guessing that Misubishi might too, but I'm not sure, and don't know where it would be located. I like the part about resetting the car with a hammer, though...
Can you get the pump to run by manually operating the relay or jumpering power to the pump? mOn the last one of those that I did, I removed the relay cover to manually close the contacts for pressure testing.
As for the PCM killing the ignition, yes. The PCM operates the ignition, so it can certainly prevent it from operating, too. Is there some sort of anti-theft device on the car? No fuel pump - no ignition, sounds a lot like VATS to me.
Old Feb 6, 2003 | 09:57 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Vader, I think that there is a vats of some sort on there. I didn't think of that. I am gonna try to get a pcm from the salvage yard tomorrow and try it anyway.
Frozer!!!
Jan 19, 2024 04:55 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
djmarch
Aug 9, 2015 05:27 PM
Newguy91rs
Aug 7, 2015 09:51 PM
