Need help with my engine combo please.
Old Feb 7, 2003 | 09:01 AM
CEDOE's Avatar
Before someone tells me to search "It isnt working". This will be a daily driver also. 89 Formula 350 TPI with auto
Ok this is what I have. L98 block bored .03 over,Edelbrock 190 aluminum heads(2.02/1.6 valves),SLP 1 3/4 coated headers(no air),Edelbrock cat back(no cat),self ported and matched plennum and stock runners,and will be using the ford injectors, I also have everything i need to burn my chips(still reading up on that).also will be going with about a 2400 stall.
My question is cam and Roller rocker ratio. these are the cams im looking at. What would be better for me or any other suggestions are welcome. Also are 1.6 RR worth it?
ZZ4 cam
Hot Cam
What kind of power should i expect?
Old Feb 7, 2003 | 09:03 AM
CEDOE's Avatar
also compression will be about 9.8
Old Feb 7, 2003 | 12:19 PM
CEDOE's Avatar
I am ready to buy my cam and rocker arms so i can get this engine together.
anyone using these cams let me know whar yall think please
Old Feb 7, 2003 | 12:26 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
You can't beat the hot cam for the price. I'd take the hot cam over the zz3/4, but there are others out there that are better...
Old Feb 7, 2003 | 04:25 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Although a bit pricy, ya might wanna consider a LPE 74211 cam. It's designed especially for TPI.
That's what I'll be using in my TPI383 eng. along with 1.6 Comp Pro Mags.
As far as power goes, the stock runners and intake will hold you back from making any serious HP gains.
Old Feb 7, 2003 | 04:39 PM
CEDOE's Avatar
Thanks do you have a link to that cam?
I have looked at the aftermarket runners and intakes but with everything else im doing at this time its out of my budget for now.
but its easy to add down the road.
What intake would you recomend?
Old Feb 7, 2003 | 11:48 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
http://www.lingenfelter.com/lingenfe...24&pf%5Fid=489
I'm planning on a Accel intake, mainly to keep it all LPE/Accel.
Old Feb 7, 2003 | 11:59 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
I 2nd the LPE 211. A little pricey, but proven to be a great performer with TPI. No experience with those heads, but if everything is done right and tuned, I don't see why you can't run high 12's.
Old Feb 8, 2003 | 04:12 PM
CEDOE's Avatar
Thanks for the help guys!
I guess i will look hard at the LPE cam.
Azrael91966669
25
Jun 20, 2017 04:04 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
nuggie
Aug 25, 2015 01:27 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
