which heads would you suggest?
Old Feb 26, 2003 | 12:51 PM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
Transmission: T-5 NWC
hi to all fellow third genners.
i'm in the process of rebuilding my old pre-86, 350, .020 over, dished pistons...( ) the block is a 4 bolt main, 2 piece rear main oil seal.
i have 2 sets of heads, and i would like to know what do you guys think (way different both and the intake manifold is not an issue)
1- P/N 14014416 "305 HO" 1.84 / 1.50 58cc. or...
2- P/N 14102193, 87 up, 1.94 / 1.50, combustion chamber size unknown, but bigger runners.
i wanted to use the 305 heads, because of the 58cc CC, but the bigger intake valves of the other set sounds good to me.
so, i need some advice from you dear friends.
thanks to all for your time.
Fernando.
Old Feb 26, 2003 | 01:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The 193 IIRC are truck TBI heads {insert gagging sounds here}
Use the 416s, have larger valves put in them, and port them. They will be far better that way than any TBI heads could ever be, no matter what size valves are in them. Get any other machine work done at the same time; such as screw-in studs & guide plates, spring pocket cutout, enlarge the push rod slots to holes, cut guides down to .530" or .500" for Teflon seals, etc. etc.
Old Feb 26, 2003 | 01:23 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I see what you mean about the TBI truck heads RB, I just took mine off what could they have been thinking?
Old Feb 26, 2003 | 01:27 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
88, what casting # are yours? Are they 193s?
I don't really understand that"design feature". Well, I understand what it does, just not why they thought they should do it. I guess it's for low-end torque and all that but it comes at a pretty steep penalty. I guess now you know why your truck ran the way those do.... no top end whatsoever.
Old Feb 26, 2003 | 03:20 PM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
so you guys think those heads are a piece of crap?
shame on the *** who design them.
well so far the 416's are, they are overhauled and ported already but still are 1.84, if it is better than those crappy truck heads, then 416 it is.
any other suggestion?
thanks to all brothers.
Fernando.
Old Feb 27, 2003 | 01:13 PM
Car: '85 IROC
Engine: LB9
My heads are 193's.
I think I've got it figured out, they built a 'ramp' into the intake port to help the incoming charge 'get air' before entering the chamber
As far as other suggestions, I can't think of any that won't cost money.
Old Feb 27, 2003 | 02:07 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
use the 416's. install 1.94" valves and port them further.
Old Feb 27, 2003 | 07:59 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Fernando.
Yeah, Fernando! Put 1.94" intake valves in. It should be worth about 10 hp at high rpms.
Old Feb 28, 2003 | 01:22 PM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
hello, nice to hear from you again dear sitting bull, our frien f-bird 88 and you and the other friends got it.
416 it is, i dont have now the money to install biger valves, but its a promisse, next overhaul, will go 1.94 and better porting.
but as it is, i'll do some research and i'll post the results, so guys in the future can have some additional info.
thanks again.
Fernando.
theshackle
Mar 5, 2017 06:37 PM
509 camaro fan
Sep 6, 2015 10:43 AM
NinjaNife
Aug 23, 2015 11:49 AM
InfinityShade
Aug 22, 2015 08:00 PM
drathaar907
Aug 6, 2015 04:20 PM
