Gas smell???
Old Mar 5, 2003 | 08:11 PM
1991Formula350's Avatar
Car: 1992 Formula
Transmission: auto stock
Axle/Gears: 3:42
Gas smell???
Hello, I have a dumb question, I smell gas in both my Formulas! Both are '91 and one has 140K and the other 10K and both had fuel filters changed, but at times it smells of gas and I feel like a dork driving theese clean mean machines and cant find the problem. Anybody else have this third gen problem? Andy
Old Mar 6, 2003 | 08:13 PM
BLUETA's Avatar
Car: 86 TRANSAM
Engine: 406
Does it smell like it is coming from under the hood ?? Check around the charcol canister. My smell was so strong I thought I had a fuel leak. But it was in canister area. The hoses were not sealing tightly. I added metal hose clips on the hoses where they entered the canister and that solved it.
Old Mar 6, 2003 | 08:39 PM
BOTTLEDZ28's Avatar
Transmission: A4
As stated above,check to see where its coming from? You may have an O ring that is not sealing correctly too. This isnt easy to find though. Check the canisiter first. also check and see if the fuel pressure regualtor looks wet. the diaphram may be leaking small amounts of fuel.
Old Mar 8, 2003 | 09:20 AM
Car: 1992 Formula
Axle/Gears: 3:42
Thank you for the help guys! But can you please tell me where the canister is located at, thanks! Andy
Old Mar 8, 2003 | 03:39 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
There has been a recall for leaking gas tank filler necks!!
Old Mar 9, 2003 | 08:44 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Do your cars have cats?
Old Mar 9, 2003 | 11:47 AM
Car: 1992 Formula
Axle/Gears: 3:42
Yes, both of mine have cat system, but that smell thing gets old after a while, recall no good now I guess huh? Thanks for helping guys! Andy
Old Mar 11, 2003 | 06:02 PM
jbcmyk's Avatar
gastank
check out your filler neck at the tank. these a recall from 94 for leaks from that area.
my 92 rs w/180k has that problem now. waiting to here from NHTSA.
Old Mar 11, 2003 | 06:40 PM
Car: 1992 Formula
Axle/Gears: 3:42
[SIZE=1][SIZE=1][SIZE=1]Who is that? Is the recall no good now after all those years? I wonder, but I need to get under car somehow to check from where you say, Thanks! Andy
Old Mar 11, 2003 | 08:08 PM
smkehndas's Avatar
Car: 02 Xtreme Blazer now
Engine: 4.3 v-6
Transmission: an automatic one! haha
yeah i got the same damn problem!!! but i just replaced my gas tank about 3 weeks ago. the smell is sometimes very strong. but i still can seem to find it.
Old Mar 12, 2003 | 07:12 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
HTH's:
Code:
NHTSA CAMPAIGN ID Number:  94V077000
Component:  FUEL:FUEL TANK ASSEMBLY:PIPE:FILLER:NECK
Manufacturer:  GENERAL MOTORS CORP.
Year: 1992 Make: CHEVROLET  Model: CAMARO  Recall Date: 05/03/1994
Type of Report: Vehicle
Potential Number of Units Affected: 232988
Manufactured: 10/1989 - 08/1992
Defect Summary:
THE FUEL FILLER NECK SOLDER JOINT CAN DEVELOP CRACKS OR PIN HOLE LEAKS, WHICH
DOES NOT COMPLY WITH FMVSS NO. 301, "FUEL SYSTEM INTEGRITY." THE CRACKS AND
HOLES CAN ALLOW FUEL VAPOR AND FUEL LEAKAGE.
Consequence Summary:
CONSEQUENCE OF NON-COMPLIANCE: GASOLINE VAPORS AND FUEL LEAKS CAN RESULT IN
A FIRE IF EXPOSED TO A SOURCE OF IGNITION.
Corrective Summary:
DEALERS WILL INSPECT THE FUEL TANK ASSEMBLY AND REPLACE THOSE WHICH EXHIBIT
THE CRACKS OR PIN HOLE LEAKS.
NOTE: IF YOUR VEHICLE IS PRESENTED TO AN AUTHORIZED DEALER ON AN AGREED UPON
SERVICE DATE AND THE REMEDY IS NOT PROVIDED WITHIN A REASONABLE AMOUNT OF TIME
OR THE REMEDY DOES NOT CORRECT THE NONCOMPLIANCE, PLEASE CONTACT CHEVROLET
AT1-800-222-1020 OR PONTIAC AT 1-800-762-2737. ALSO, CONTACT THE NATIONAL
HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-800-424-9393
RBob.
Old Mar 12, 2003 | 10:49 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The canister is that huge black cylinder behind the driver's side headlight.
Old Mar 12, 2003 | 11:13 PM
Slade1's Avatar
Check if your gas cap seals properly, even after I nailed the fillerneck problem, my gas cap didn't seal well allowing fuel out on hard turns...
Old Mar 13, 2003 | 01:06 AM
bigals87z28's Avatar
Car: Check The Sig
what if you have an 87, and you can smell it mostly from the drivers seat (when the door is open) to the front... cant you replace the filter in the canister?
Twin_Turbo
Mar 14, 2016 10:10 PM
Dwayne614
Sep 29, 2015 11:05 PM
Racerx974
Sep 19, 2015 10:16 AM
earlpote
Sep 12, 2015 11:55 AM
Glowsock
Sep 11, 2015 11:09 PM
