How do you know which LB9 you have?
Old Apr 18, 2003 | 01:40 PM
91 Camaro Z28's Avatar
I have a 91Z28 w/the 305TPI LB9 (8th vin=F)
how do i know which LB9 i have because according to this TGO Tech Page there were 2 LB9s availible in 91. 205hp and 230- how do i know which one i have?
Old Apr 18, 2003 | 01:47 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Do you have 2 cats or 1? I believe the 2 cat ones had the higher hp.
Old Apr 18, 2003 | 01:53 PM
one cat- anyone else know for sure?
Old Apr 18, 2003 | 02:43 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Was your car an Auto from the factory? If it was then you have the 205. If it was the manual, then Single cat=205 and Dual Cat=230.
Old Apr 18, 2003 | 04:34 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Yup, dual cats = 230hp, and single cat = 205hp.
In the old days it was thought that besides the exhaust that the cam was smaller in the single cat car too. That has been proven untrue both by direct parts identification (i.e. people with single cat LB9s pulled cams and check #s) as well as indirectly (90-> single cat LB9s repond much better to mods than early peanut cam cars and are identical performance-wise with the dual cat cars once you upgrade exhaust)
Old Apr 18, 2003 | 06:08 PM
boo.....i only have a 200hp V-8?????? thats so stinkin weak-- no wonder my e.ts suck... i need a new motor- any suggestions??
Old Apr 18, 2003 | 11:26 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
HP is not everything. You've got more torque than that. Besides you can mod the crap out of 305's or 350's. And building a 350 is not that expensive if you do the work yourself.
Old Apr 19, 2003 | 07:05 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
You must have the Stock 5 sp manual and dual cats for the 230 hp LB9 option. All Autos came with a single cat and 205 HP from the factory for that year.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
gta90
Sep 15, 2015 04:00 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
mrestrictrplate
Aug 27, 2015 09:37 AM
happyhapka
Aug 15, 2015 04:42 PM
