Manifold glowing orange
Old May 10, 2003 | 10:06 PM
chrisj678's Avatar
91, camaro rs 3.1
My car has been eating spark plug wires. what i mean is its been melting down the boots. I'v gone through about 4 sets in a month. I drove for about a half hour and got home and poped the hood and saw the passenger side manifold glowing orange out side of one of the cylinders.
Why would it do this?
thanks
chris
Old May 10, 2003 | 10:23 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
look for an injector sticking open (or leaking) in the cylinder that corresponds to the glowing red section of the manifold
Old May 10, 2003 | 11:29 PM
25thanniversZ's Avatar
could possiblly be the cat convert
Old May 10, 2003 | 11:32 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
how do you figure?
it sounds like you may be running lean. check your fuel pressure regulator.
Old May 11, 2003 | 01:06 AM
Morley's Avatar
Might have an injector not flowing enough and running that cylinder very lean, not a good thing to drive around on. and being on the passenger side the O2 sensor can't help by triggering a light for lean condition.
Old May 11, 2003 | 08:53 AM
i've always heard of glowing exhaust manoifolds from being too rich
so rich, that the fuel is still igniting inside the exhaust manifold making it glow
i think it would be way more complicated if was caused by a lean condiditon
Old May 11, 2003 | 10:59 AM
mw66nova's Avatar
Engine: 7.0L
do a search on glowing exhaust primaries 1991 tealt-topguy or whatever your name is. everyone suggest it is lean...when they richen the mixture up, the problem is solved. i don't know the physics behind it, i just know what causes the problem and how to rectify it.
Old May 11, 2003 | 01:04 PM
Morley's Avatar
If it is overly rich the cylinder temp will be cool becauce the fuel that didn't get burned is cooling the combustion chamber. Lean burning ie very hot and makes headers/manifolds glow from the heat.
Old May 11, 2003 | 05:21 PM
Scarebird's Avatar
Car: 1998 Z28 convertible
Transmission: 700-R4
I would suggest you take a look at your timing; it may be retarded.
Old May 11, 2003 | 09:18 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Lean condition. Sticky/plugged injector small intake manifold leak PS intake but that would cause high idle.
Old May 11, 2003 | 09:28 PM
when i first heard of glowing manifolds so long ago (never happened to me) i thought it was a lean condition that caused it
then a few people told me it was a too rich of a condition
now, that i think about it, the rich theory seems more far fetched than running lean
thanx for the correction
Old May 12, 2003 | 12:07 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Two causes of glowing.
Lean causes a slight glow, usually, dependign on how lean.
MASSIVELY retarded timing will cause a BRIGHT glow, and sometimes even make the yy-pipe glow orange. This is because the air-fuel mixture was ignited so late, it is still combusting on its way out the exhaust.
Good way to melt a cat... ask me how I know...
Old May 12, 2003 | 01:00 AM
Morley's Avatar
He has noted that it is just on the one cylinder's exhaust port, this leads me to believe it is an injector causing one cylinder to run lean.
Old May 12, 2003 | 01:03 AM
99Hawk120's Avatar
Sorry, I wasn't answering the original question, just trying to dispel some of the above confusion.
Old May 12, 2003 | 02:40 AM
Morley's Avatar
Ahhhhhh. A horse of a different color.
And you better watch what you do to cats or the S.P.C.A. will be after you
Old May 12, 2003 | 06:04 AM
chrisj678's Avatar
thankyou to everyone who posted their input
chris
Old May 13, 2003 | 02:46 PM
chrisj678's Avatar
In the end
A buddy of mine told me to change the o2 sensor it was bad so i did and with some new wires it seems to be running even better than when i bought the car also it runs temp cooler.
Old May 13, 2003 | 02:55 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
the 02 sensor is in the y-pipe after the 2 sides join on a v6 car... at least it was on my 2.8 cars.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
Elephantismo
Feb 13, 2019 12:51 AM
gta892000
Sep 16, 2015 12:37 AM
