New engine setup should i keep my EGR?
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
IM installing a SuperRamed 406 I have the option of keeping the EGR or deleting it. I dont have to worry about emissions testing they did away with it here in Florida. What do you guys think? What would be better for performance? I need to know for when it comes time to burn the new chip!
Thanks,
Mike
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Thanks,
Mike
Car: 90 IROC
Engine: 406
Thanks Jeff...Oh yes.. the rattle of death!
I dont know of any good reasons to delete it. My PR chip has an EGR delete too it. Thats why I wondered if I should do away with it. Why would they?
Mike
Mike
Yah there is a problem with it. Whatever your engine sucks down in recycled exaust fumes, it's not sucking down in fresh air and fuel. Not to mention it gets your engine dirtier, and heating the helll out of the intake charge. I don't know how much diff, if any, it makes on a dyno but in theory it sure doesn't sound healthy to me.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
Jesters's Page of Sick Pleasure
Florida Thirdgenners Message Board
ICON Motorsports
ICON Motorsports
Transmission: 4L80E/4L80E
I'd agree with Jester. The PCV doesn't hurt anything (unless you have extreme blow-by), but I wouldn't say the same for EGR. If you don't have to pass emissions, and especially if it's a strip-only car, delete the EGR.
Don't throw it away, though. You may not have emissions testing in Florida today, but there's always tomorrow to the Feds.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 3.08 open, cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, World 305 heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Car: 90 IROC
Engine: 406
Yeah...Maybe ill just hook it all up and when i go too have the chip dynoed see what they say about it.
I did notice swapping the PR chip back and forth for the stock one. That with the stock chip the car would sometimes surge at part throttle tip in. I dont know if it had anything to do with the EGR though.
Thanks!
Thanks!
Mike,
The EGR shouldn't have mattered at throttle tip-in (nor at the strip, for that matter) since the only time an EGR is supposed to be opened is at part-throttle cruise. Idle and WOT should have a fully closed EGR. For the sake of simplicity and space, I can understand why a strip-only car would not have an EGR. Also, most serious manifolds don't have an EGR provision. For most of us weekend warriors, the EGR is not a bad thing - especially for running pump gas.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Later,
Vader
"Make Me Bad"
Car: Take
Engine: Your
Transmission: Pick
Yes, what you gain by sucking only "fresh air" you will loose in total timing, thanks to hotter combustion chambers and the onset of detonation.
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Boxed LCAs, 8mm Accel wires, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
If you live in Southeastern US, check us out!
South East Thirdgen
Savannah, GA
'97 Bonneville SSE
South East Thirdgen
Terrell351
Jun 13, 2021 01:13 PM
mdtoren
Aug 16, 2015 05:45 PM
