A/C depressurizing on a dead motor??
Old Jun 6, 2003 | 03:10 PM
Cold Dark Shado's Avatar
Car: '86 TA wrapped in '84 skin
Engine: 305 carbed
Axle/Gears: unknown
The car in my sig has an A/C system on it that has pressure in it and i want to get it depressurized so i can remove the whole system but with a dead 2.8 how can i do it??
Old Jun 6, 2003 | 03:14 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
push the valve in with a screw driver and stand back
Old Jun 6, 2003 | 03:17 PM
Engine: 305 carbed
Axle/Gears: unknown
i would do that but i have this thing about being arrested oh yea and right now i do enjoy my lungs, even if they are crappy from 13 years of smokin lol
Old Jun 6, 2003 | 03:36 PM
MasterEvilAce's Avatar
if someone asks just tell them it exploded and went everywhere.. not your fault
Old Jun 6, 2003 | 04:07 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
well here are you choices, the above mentioned screw driver method, buy an ac machine and purge it, or tow it to a shop that has an ac machine and have them purge it.
Old Jun 6, 2003 | 05:45 PM
RICHRAD's Avatar
Go outside while it's dark and push the freaking valve
Old Jun 6, 2003 | 09:32 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I agree the hard part is its dead because alot of small shops that do a/c will take the freon and not charge you being r12 cost so much its worth it to them to take it
Old Jun 6, 2003 | 11:12 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
just push the the valve in and it will be depressureized in a min or two.
Old Jun 7, 2003 | 02:49 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
If you're going to swap in a 3.4 or 3.1 to take the 2.8's place, you can remove the entire a/c system without cracking open any fittings or losing any freon. I posted how a few days ago on the v6 forum (and a few times on this main tech forum too!) if you do a search for "remove condensor accumulator" by TomP...
Old Jun 7, 2003 | 02:51 AM
Engine: 305 carbed
Axle/Gears: unknown
yea im goin with a 3.4. I just want to get rid of the AC all together cuz i dont want it.
Old Jun 23, 2003 | 07:58 AM
87350IROC's Avatar
Car: 87' IROC
Can pull the whole system in the 350 car too? Or is it just possible for cars with the V-6?
JP
Old Jun 23, 2003 | 10:59 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
It probably is. The box on the firewall (heater/evaporator box) is the same box. If there's nothing blocking the hoses from getting lifted up, you're good. The compressor is on the passenger side, right? On the v6's, it's on the driver's side.
Old Jun 23, 2003 | 11:39 AM
87350IROC's Avatar
Car: 87' IROC
Nope, driver side. I think later v8s had them on the pass side, but not in 87'. That would be nice. I'd perfer not to purge the system into the atmosphere and have to recharge it. .
Old Jun 23, 2003 | 11:43 AM
Engine: 305 carbed
Axle/Gears: unknown
yea i just let it loose and i STILL havent taken any of the damn thing out and its been a couple weeks now lol
Old Jun 23, 2003 | 12:39 PM
Jurrel's Avatar
Car: 1984 Firebird
Engine: 2.8 Carburated
Transmission: T5 Manual
HEY! If you do not want the A/C compressor let me KNOW!
I just blew apart my old one and if I can get a known good one cheap Im all for it!
Let me know if you manage to depressurize the system and get it removed!
Old Jun 23, 2003 | 01:25 PM
Engine: 305 carbed
Axle/Gears: unknown
the system is depressurized and all i got to do is unbolt the thing. If your lookin for one LMK, im partin out the car so we can work something out
Old Jun 23, 2003 | 05:36 PM
Jurrel's Avatar
Car: 1984 Firebird
You have a PM
Old Jun 23, 2003 | 08:34 PM
87350IROC's Avatar
Car: 87' IROC
Tom, could you circle or indicate which items need to be removed. Here's what I have so far... The condensor in front of the radiator, the compressor on the driverside pulley, the silver cylinder on the pass side, the plastic box behind it, the box to the left of it that has a "warning refridgerant under pressure" sticker, and all associated hoses. Anything else, or anything i mentioned that i don't need to remove? How do i remove the stuff from the firewall?
JP
evilstuie
Jan 9, 2020 08:29 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
zayne0
Aug 24, 2015 07:22 PM
Bradsaundry
Aug 12, 2015 12:34 AM
