TPIS MAT relocator kit
Old Sep 28, 2000 | 04:40 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Is TPIS kit the only one that uses an LT1 MAT sensor ? I'd rather cut a finger off than buy something from them.Does the LPE kit come with an LT1 sensor ? I'm not sure who else makes the kits , so if you know of others please post them.Thanks
92Z28
89GTA
Old Sep 28, 2000 | 05:55 PM
rondubbs's Avatar
jegs page 103. part # 561-61630
$46.99
Old Sep 28, 2000 | 08:49 PM
84IROC's Avatar
Why do you need a kit? I just went on over to the local auto parts store and requested the specific sensor I wanted and then found a grommet that the sensor would fit in. Then I went home and bored a hole in my airbox, slid the grommet in and snapped the sensor in place and extended the harness about 18 inches, wrapped it all up in convoluted tubing and WA-LA: homebrewed MAT relocate kit!
"84Z28/'91 305TPI comp cam flowmaster TB coolant bypass/shutoff valve to heater core MAT relocated Ram-Air(home-made) gutted air-box IROC ground effects/wheels GY245/50's 700R4 superior shift kit/ corvette servo(excellent shift kit BTW) Rebuilt engine and transplanted it myself. Love this engine!
LOW performance people should drive low performance vehicles!
Old Sep 28, 2000 | 09:36 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
I'm with '84, why pay that much when you can do it yourself for less $$ and more satisfaction?
Old Sep 28, 2000 | 09:42 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
How much is an LT1 MAT? Do I say I want a MAT for a 93-98 TA?
Old Sep 28, 2000 | 11:13 PM
CanadianBeast's Avatar
What benefits are there to relocating the MAT?
Old Sep 28, 2000 | 11:47 PM
Vader's Avatar
CanBeast,
The original location for the MAT is on the underside of the intake plenum. During normal operation, the plenum will leach heat from the intake base. This tends to artificially heat the sensor, causing a potentially erroneous reading to be reported to the ECM (generally hotter than the actual air temperature). When the ECM detects warmer intake air, the fuel mixture gets some lean offset. To remedy this, the MAT sensor can be located farther upstream in the intake ductwork. If you question the validity of this project, GM didn't. They moved the MAT sensor on LT1 engines to the intake duct in 1993. Problem solved.
Incidentally, I'm with '84 and Red Devil - I did mine for less than $30.00 with a new sensor. If you're interested ing some details of the project, including part numbers, check this link: MAT Relocation. You'll need Adobe Acrobat Reader to view/print the file (see link below).
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Oct 1, 2000 | 10:20 AM
danomano's Avatar
Vader I checked out your work and it looks real good but where can the sensor be put on the firebirds?
Old Oct 1, 2000 | 01:20 PM
rondubbs's Avatar
on firebirds it is put between the maf and tb.
jaridjohn
Jul 8, 2024 03:49 PM
lee01
Apr 9, 2016 01:56 PM
Thornburg
Aug 25, 2015 01:46 AM
Sanjay
Aug 12, 2015 03:41 PM
