new engine, first time starting..problems
Old Jul 12, 2003 | 08:49 PM
cr125r's Avatar
Car: 1988 trans am
Engine: 5.7 gm H.O. crate engine
well, today i finished the installation of my new engine. about 15 minutes ago, i cranked her over. it fired right up with a rough idle and died the next couple seconds. it keeps doing this. i got one backfire through the carb. i have a 1988 carb 5.7 trans am. used to be a tbi 5.0. is this a timing issue. i have it set at zero i believe. thanks for your time
Old Jul 12, 2003 | 08:53 PM
icebird_1981's Avatar
use to have the same problem it would start right up then die, turned out there was something up with the carb, got it rebuilt and all was fine. check the carb out make sure everything is working good.
Old Jul 12, 2003 | 08:56 PM
cr125r's Avatar
Car: 1988 trans am
its a brand new carb though
Old Jul 12, 2003 | 11:14 PM
rustybluebird's Avatar
Car: 87 Firebird
Engine: 350, 416's, 230/230 cam, torkerII, q-jet
What type of distributor are you using?
Do you know if the valve lash is set properly?
Don't take this as an insult, but are all your plug wires on right, etc.
Most of the time it is a simple yet very elusive problem.
Old Jul 13, 2003 | 12:34 AM
Soulrev's Avatar
Car: Formerly - 87 T/A, 87 Bird.
Right, as Rusty said most of the time it's a simple problem.
However, never, ever assume that because something is new it's going to work right, and then eliminate it from the list of possible problems. I used to work at an auto parts store and I can't tell you how many times people brought defective parts back.. I can't tell you how many times I have gotten a defective part.
Old Jul 13, 2003 | 01:26 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Yep, run through the valves again, sounds like one is overtightened.
Can be one of the other probs though...
Old Jul 13, 2003 | 07:28 AM
cr125r's Avatar
Car: 1988 trans am
would someone be able to tell me how to set the valve lash? also, when putting the wires on the dist. they go in a clockwise fashion with the firing order?
Old Jul 13, 2003 | 07:32 AM
cr125r's Avatar
Car: 1988 trans am
proform hei with an incap coil
Old Jul 13, 2003 | 09:18 AM
cr125r's Avatar
Car: 1988 trans am
timing, valve lash, plug wires, or a vaccum leak is what i think it may be, what else?
Old Jul 13, 2003 | 08:57 PM
cr125r's Avatar
Car: 1988 trans am
well, i just got home and decided to check my spark plug wires. turns out the 6 & 8 were switched . ill have to try it tomorrow at 6 when i get home from work, too late for open headers.
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
