Is this too good to be true
Old Aug 8, 2003 | 09:31 AM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
Ok let me know guys... it says there off of a 89 formula H.O so that means it has to fit my car right??
i got a lo3 305 TBI and these heads would go perfect with my lt1 cam and edle brock rpm intake!!
please dont bid on these as i really need these cheap heads!!
even though i swore id never take my heads off again i think i may make an exception
http://cgi.ebay.com/ebaymotors/ws/eb...item=242691201
Old Aug 8, 2003 | 09:33 AM
TransAmTBI's Avatar
Engine: 305 TBI
well the links not working but will H.O heads from a formula 305 be a good choice? i e-maild him on the casting nmbner so i'll let you guys know the casting nukmbers when i get them
Old Aug 8, 2003 | 10:04 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There's no such thing as "Formula HO". The HO motor was discontinued in these cars before the Formula was revived in this generation of F cars.
Get a casting number. That cuts right through all the BS and drivel and mis-identification, and gets straight to the reality of what they really are.
You need casting number 081. They came on 305 TPI motors (which are not "HO" motors), and the HO motors in 87 Monte Carlo SS.
Old Aug 8, 2003 | 03:01 PM
TransAmTBI's Avatar
Engine: 305 TBI
i thought 081 was for the swirl ports???
can you give me the castings for the swirl ports
Old Aug 8, 2003 | 03:08 PM
TransAmTBI's Avatar
Engine: 305 TBI
14101081 is that right??
he says 87 formula with a 305 ho roller motor is he just mistaken??
Old Aug 8, 2003 | 03:09 PM
TransAmTBI's Avatar
Engine: 305 TBI
sorry last one for now
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2426961201
Old Aug 8, 2003 | 03:37 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There was no "HO" motor in 87 in a Formula. People call just about everything a "HO" these days, just like they call things "police interceptor" or "from a Vette". It is usually meaningless BS buzzwords used for the sole specific purpose of making inexperienced and uninformed people think that something ordinary is actually something special, even when it's not.
In 87 there was the TPI motor, which is a roller motor; and there was also the LG4 carb motor, which is also roller. Both of those would have come with the 081 heads. Neither of them was the "HO", because the last year of the motor that [i]was[/b] actually called the "HO" by GM, was 86.
Old Aug 8, 2003 | 05:58 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
i know this may be non thirdgen tech but i'm still going to ask.
rb, when you say gm last produced a h.o. engine in 1986, are you referring to strictly the f-body? or is that for all gm cars?
not disputing you, but also trying to make sure the information i've heard and seen is accurate.
monte carlo ss models got the h.o. through 1988, correct?
Old Aug 8, 2003 | 06:56 PM
TransAmTBI's Avatar
Engine: 305 TBI
ok so either way 081 casting def is NOT swirl port! right?
also are the heads the same for the Tpi and carb LG4?? should i ask if its carb or not or are they still good?
Old Aug 8, 2003 | 07:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
RobertG:
Yes, that is correct. The L69 continued to exist AFAIK until the end of the MC SS. I know for cetain that it existed, because my late little brother's car (that he died in) had one. It was discontinued in these cars after 86.
081 is definitely not swirl-port.
Old Aug 8, 2003 | 07:31 PM
Guest
Guest
Posts: n/a
14101081...87-95...305
i got that info off
http://www.mortec.com/castnum.htm
i wish it told me the vavle size and all that.
i'm tryign to get more info on the heads off my 350 and off my 305 i don't know what heads will be better to use.
Old Aug 8, 2003 | 07:59 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
dude my car came stock with the corvette tuned port injection on my 305 iroc!!
Old Aug 8, 2003 | 08:06 PM
Guest
Guest
Posts: n/a
and your point is what?
Old Aug 8, 2003 | 08:41 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
so you have the corvette lower? with the egr tube? and you are sure the distributor cover was aluminum from the factory on your car? and the fuel lines enter on the pass side?
Old Aug 9, 2003 | 07:00 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
{In my best Beavis voice} Monkey-Spank!! He-hee-he-he
I forgot to mention, my little bro's MC SS was a 87.
The 081s have 1.84"/1.5" valves and 58cc chambers, and no swirlies. The ones you want to avoid are the ones you should have on your TBI motor, which are 187s IIRC.
Old May 21, 2007 | 08:33 PM
TuDogs3's Avatar
Re: Is this too good to be true
193 is swirl port
okfoz
Mar 9, 2017 02:35 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
