Do 3rd gens need traction bars?
Old Aug 14, 2003 | 05:21 AM
Z28Clone's Avatar
Ran my 3rdgen for the first time at the strip yesterday. Ran 14.9. I chirped bad at the line. Will traction bars fix my problem? WIll it be a simple bolt on or will any mods be needed? Thanks
Old Aug 14, 2003 | 05:47 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
I have had success by installing tubular control arms, dropping tire pressure and either loosening up the front sway bar or better yet removing it.
Judging by your ET, you may only need to put a set of stickier tires on.
www.geocities.com\dzperf
Old Aug 14, 2003 | 10:27 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Thirdgens don't have leaf springs in the rear to put traction bars on.
Old Aug 14, 2003 | 10:41 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
get some sticky tires like BFG drag radials or M/T et streets.
get an AIRLIFT airbag set for third gens for the rear springs.
Tightens up the suspension, allows R/L preload bias adjustment,
adjusts pinion angle and lower control arm angle
(instant center) Without affecting normal driving. (let the air out)
Air Lift
Old Aug 14, 2003 | 11:34 AM
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
With the above mentioned changes, I was able to run mid 1.6 60' times on Mickey Thompson Competitors. These are a full tread street tire that is not a wrinkle wall. Traction on a mid to high 14 second car should not be a problem.
Old Aug 14, 2003 | 03:52 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
wider/stickier tires, boxed or tubular lca's, lca relocation brackets and airbags would help ya a lot with traction.. check out spohn site at the top of the page.. good products
Old Aug 14, 2003 | 04:25 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
NOO!! don't use any type of drag radial or anyting of thr sort, stick to normal street tires.. You have a 350 and a T-5 trans, if your do it you will most likly be investing is a new trans. Just get some relocation brackets and some lower control arms. Then just get used to the car and learn how to come out of the hole the best you can and you will be fine.
Old Aug 14, 2003 | 09:02 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
he'll probably be fine as long as he isnt dumping the clutch.
Old Aug 14, 2003 | 09:05 PM
Car: 88 Camaro SC
Engine: SFI'd 350
what does removing the swaybar do, anyway? Alow for more even loading on each of the rear tires when it launches?
Old Aug 15, 2003 | 12:17 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I think taking off the swaybar softens up the rear end, which makes it more tractible.
Old Aug 15, 2003 | 12:47 AM
83crossfireZ28's Avatar
it aids in weight transfer...
Old Aug 15, 2003 | 12:44 PM
Z28Clone's Avatar
Will removing the sway bar affect the driveability? I drive it to work (23miles 1 way) about once a week.
Old Aug 15, 2003 | 02:03 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Removing the front swaybar will allow the nose to rise higher on launch and transfer the weight to the rear wheels. Yes it will have an impact on drivability, the car will lean like a barge in corners.
Old Aug 15, 2003 | 04:46 PM
Car: 88 Camaro SC
Engine: SFI'd 350
not only that but it can cause your car to oversteer in turns if your f/r weight ratio is still close to stock. Thats interesting about the sway bar. I didnt know it hindered the suspention travel of both of the front wheels when they extend at the same time.
Old Aug 16, 2003 | 06:01 AM
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
Removal of the sway bar is not that difficult. I remove mine the day before I head to the track.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
tricky1
Aug 23, 2015 01:17 PM
