Anybody ever use "Engine RESTORE?"
Old Aug 22, 2003 | 02:53 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
I see this stuff all the time. It comes in a silver can, and supposedly can help restore proper compression.
Anybody ever used it? Or would you even use it?
Old Aug 22, 2003 | 04:57 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
I've used a couple cans of that in the LG4 at various points in it's life...it currently has 394,xxx kms (approx 250,000 miles) under it's valve covers, the heads have never been off it, and a compression test last fall showed anywhere from 185 to 210 psi among it's cylinders.
It can't be bad stuff...
Pete
Old Aug 22, 2003 | 05:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
(Edit: NM, I got the wrong stuff on the brain.)
Old Aug 22, 2003 | 06:54 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Ugnmph, If the original owner used flush once in a while. Oh well.
Some of the stuff works some makes it worse. Most of the junk on the market labeld as engine restorer is just engine honey 40w+ made to thicken the oil enough so it stops smoken and seals the rings a little better.
Old Aug 23, 2003 | 03:50 PM
Restore USA
Old Aug 23, 2003 | 05:11 PM
posbird87's Avatar
Car: 87 formie
Engine: none
Transmission: none
i used it before, stopped the smokey start ups for awhile but they came back after about a month.
so i guess its good stuff:lala:
Old Aug 23, 2003 | 05:25 PM
Damon's Avatar
My brother used it on his 160,000 mile 4.3L Blazer. It had bad compression on one cylinder (down about 25%) due to the former owner never changing the plug on that cylinder because it was "hard to reach." Oh boy.
It would get compression within 10PSI on that cylinder for a few months and then it would "go away" again. So he changed oil often and always added a can of that stuff at every oil change. Got him from 105K to 160K pretty good, when he sold it. And he beat on that pooor thing mercilessly- towing a trailer that was WAY overweight through Arizona deserts on a regular basis.
In short- it works, but expect no miracles (at least not long term miracles).
Old Dec 26, 2007 | 12:08 PM
British Rich's Avatar
Car: 92 Camaro RS
Axle/Gears: Stock
Re: Anybody ever use "Engine RESTORE?"
Cool so it DOES do what it says, especially as most of us will be due an oil change every few months anyway and they say to use it every change.
....besides if anyone expects more than that from an $8 can you just pour into your oil they are dreaming!
ok....well maybe with the exception of seafoam (when you do the THREE step)....that stuff does work and does have the clostest thing to "permanent" results you have ever seen out of a can!!
colton_carlson
Mar 8, 2019 12:21 PM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
gta power
Aug 13, 2015 06:15 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Street Lethal
Aug 12, 2015 11:33 AM
