Best heads for your money?
Old Nov 16, 2000 | 08:03 AM
know_bull88's Avatar
Is the vortec heads really the best bang for the buck or is the performance of the fast burn heads just out weight the over $1000 that they cost? does any body have exp. with both I'd really like to know you opinon?
Old Nov 16, 2000 | 06:48 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
vortecs are best bang for buck, anyone who says otherwise needs a brain transplant just check the sig, gottem for 25 bucks used and put 100 worth of springs and **** onb
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
Old Nov 16, 2000 | 07:55 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I guess it really depends what you want. Yes, they are very reasonable for the performance you get from them. Chevy High Performance did a recent build up of a Goodwrench 350 and the Vortecs (stock) produced more HP than pocket ported Aluminum L98s.
After pocket porting the Vortecs, they developed even more HP, but bone stock TFS 23* SBC heads developed even more HP.
So if MAXIMUM HP is your goal, there are better for a little more money (and some a lot more money). As I said, it depends on your ultimate objectives. If you want 350 HP, they are just fine. If you want 400+, spend more money.
Old Nov 16, 2000 | 08:01 PM
merf23's Avatar
Also, make sure you consider the cost of making them work for your application, especially if you already have parts like headers and a nice intake. You might be better off for example getting a $1000 set of heads that work with your parts, rather than a $400 set that will cost another $600 to make work.
Old Nov 16, 2000 | 08:59 PM
Car: Death Mobile
Engine: 666 c.i.
Or vice versa if you already bought the intake to work with the Vortec heads...
Old Nov 16, 2000 | 10:18 PM
JJ's Avatar
JJ
The vortecs are fine, I did sink some money into a set to get them where I wanted. I have another set that I am about to take to the shop. However, by the time I get them where I want it may be more feasible to buy something like the new trick flow heads. I will probably keep the ones I've already modified and add larger valves this winter. My remaining stock set was to go on a tpi car, I'm really considering just buying a set of trickflows and porting out the stock intake since I found out the vortec/tpi base is supposed to run around 400.00. Then again, the ramjet looks like a decent route with vortecs or fastburns.
87 IROC, 350/5 speed.
89 formula, L98.
Old Nov 17, 2000 | 08:20 AM
Thanx fellas hopefully with the combo like I saw in that chey mag with different heads I can get close to 400 as possable with vortecs and maybe 13's are in my future.......
Old Nov 17, 2000 | 09:43 AM
Car: Death Mobile
Engine: 666 c.i.
If you hook up properly, 400 HP should get you into the 12s.
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
509 camaro fan
Sep 6, 2015 10:43 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Thornburg
Sep 1, 2015 03:39 AM
