Oil Pan Question
Old Oct 4, 2003 | 10:23 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
Oil Pan Question
Have any one used a Milodon 7qt Oil Pan, part # 30900. I need to know how this would present any chasis problems. ie: Headers or crossmember interference. This is the Milodon Street/Strip Oil Pans:
Old Oct 4, 2003 | 10:34 PM
DTL504's Avatar
Here is a picture of the Milodon Street/Strip Oil Pan part#30900:
Old Oct 5, 2003 | 12:38 AM
onebinky's Avatar
It'll probably interfere with the crossmember under the engine. It's a tight fit down there, and I know a standard SBC oil pan will not work because of that. I don't know if it will interfere with the crossover pipe though.
Matt
Old Oct 5, 2003 | 07:29 AM
DTL504's Avatar
I don have to worry about the crosspipe from the exhaust because I have a custom exhaust that runs down the side of the car.
Old Oct 5, 2003 | 08:59 AM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
if you are not running the exhaust between the oil pan and crossmember, that pan will fit
Old Oct 5, 2003 | 11:46 AM
DTL504's Avatar
Here is a picture of my exhaust, so it will clear:
Attached Thumbnails Oil Pan Question-cust-1-.-y
Old Oct 5, 2003 | 02:04 PM
onebinky's Avatar
How much ground clearance do you have with that? Any more pics of how it is ran?? I'm looking to do that too, but the roads around here are crap and I don't want to smash my pipes.
Matt
Old Oct 5, 2003 | 02:57 PM
DTL504's Avatar
Here is a link to the setup:
https://www.thirdgen.org/techbb2/sho...hreadid=155711
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
MY87LT
Aug 17, 2015 08:43 AM
gwade12
Aug 8, 2015 08:17 AM
