New motor, won't crank........
Old Oct 6, 2003 | 11:42 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I don't think its anything mayjor. Got the motor in, the only thing that I noticed was that I didn't plug in one male plug in the rear of the engine bay. I think it went to some emssions equipment.
Anyway, I turn the key, I can here the pump prime and the dash lights up as usual, but I turn to start and she does nothing. Battery is new, starter is not. I know the started is old, but it work perfectly when I took it apart. Although it has been sitting for 5+ months.
Please let me know what you think.
PS- the crap in my sig is the old build up (null and void)
Old Oct 6, 2003 | 12:44 PM
jimmy_mac's Avatar
I think after making sure I had all the wires connected to the starter I would see if I was getting 12 volts to the smaller one on the solenoid that tells it to engage the starter when the key is turned on. Just unhook it and have someone turn the key while you take the reading. If not then start working backwards.
Old Oct 6, 2003 | 02:47 PM
rezinn's Avatar
You should make sure you've got everything plugged in too. There's nothing you can leave disconnected and not affect how the car runs, except maybe the diverter valve, washer pump, things like that. Might want to check your grounds as well.
Old Oct 6, 2003 | 03:56 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
I'll let you know how it goes. I'm going to try and work on it tonight.
Old Oct 6, 2003 | 04:05 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
If all wired correctly...sures seems like a VAT's issue.
Pull codes from the ECM, see if the VAT's pop's up.
Old Oct 6, 2003 | 04:28 PM
jimmy_mac's Avatar
ye, if the starter ain't getting the power, it's quick and easy to run a jumper on the starter rely in the driver's side kick panel to bypass the vats just to see if that's the issue.
If it's an auto then theres a relay in the sifter also I think. To make sure it's in park.
Old Oct 6, 2003 | 04:30 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
That will get you the starter to crank, but the injectors still won't fire.
Old Oct 6, 2003 | 05:39 PM
TJQIROC's Avatar
Car: '16 Camaro SS, '88 IROC
Engine: 6.2 Gen V
Transmission: 6 spd TR6060
There was a similar post last week and the cure was he forgot to connect the neutral safety switch in the console. Same goes for the clutch, if you have one. Another quick test, attach a remote starter to the solenoid. That would confirm if the starter does in fact work. You could even use a screwdriver to jump out the starter. Just make sure the car is in neutral. Then back track from there. If it is something as simple as a bad/disconnected neutral safety swith or ignition swith, you should be able to start the car with the key on with the remote starter. Thats assuming its not a VATS problem.
Old Oct 6, 2003 | 07:26 PM
jimmy_mac's Avatar
That's just to figure out what the problem is, not a permanent solution.
Old Oct 7, 2003 | 07:51 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Turns out the stud coming out of the started was loose. tightened that and is started right up. Thanks. Sorry for the stupid question.
1992rs/ss
Jan 31, 2025 05:10 PM
Derick15
Sep 17, 2016 05:28 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
E Rod
Aug 28, 2015 05:17 AM
slade5612
Aug 11, 2015 07:19 PM
