Drivers side fan refuses to come on
Old Dec 13, 2000 | 11:19 AM
theformula's Avatar
Ok, I have a JET 195* fan switch.
Lately I noticed my car hasnt been cooling as efficiently as before.
Ok, usually the fan switch engages after 195* and cools to 180* with BOTH fans. I looked under the hood today and only the passenger side fan was working.
I have a manual fan switch I rigged, usually it turns both fans on. I flipped it on and the drivers side fan STILL didnt come on.
I even cussed at my fan and threatened it with a jack handle. Still didnt work
Any suggestions?
91 Formula
305 TPI 5speed
1LE package
Custom cold air intake w/K&N, SLP airfoil, ported plenum, Crane AFPR (47psi),MSD6AL, Holley 9mm Annihilator wires, Ac Delco cap,rotor and plugs, Bosch O2sensor, Slp 1 5/8 headers and catback (all stainless steel!), 3:73s,JET 195* fan switch, Macewen white face gauges, Intellitronix Digital Gauges
Stock throttle body,intake manifold,cam, and heads.
[This message has been edited by theformula (edited December 13, 2000).]
Old Dec 13, 2000 | 05:18 PM
ede's Avatar
ede
the motor is burt up. run a jumper from the battery and see if the fan runs then. if not it's a good bet the motor is shot.
ICON Motorsports
1st & 3rd
Old Dec 13, 2000 | 06:20 PM
theformula's Avatar
How much does a motor run for that car?
Thanks ede.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Custom cold air intake w/K&N, SLP airfoil, ported plenum, Crane AFPR (47psi),Crane Ext Alum 1.6 full roller rockers, Timing set from 4*BTDC to 10*,MSD6AL, Holley 9mm Annihilator wires, Ac Delco cap,rotor and plugs, Bosch O2sensor, Slp 1 5/8 headers and catback (all stainless steel!), 3:73s,JET 195* fan switch, Macewen white face gauges, Intellitronix Digital Gauges
Stock throttle body, runners,intake manifold,cam, and heads.
Old Dec 14, 2000 | 01:23 PM
Stuart Moss's Avatar
Better yet, remove the corresponding fan relay and jumper (short) the two sockets with the large diameter wires connected to them. One wire goes to the battery positive terminal through a fusible link, the other goes to the fan. (The relay switches these points.)
The can be off when doing this test since the wire comes directly from the battery.
This test will not only test the fan motor, but also the associated wiring, including fan motor ground, and connections between the fan motor, relay socket and battery.
If the fan does not come one, I would check for +12 at the relay socket. Perhaps the fusible link opened. Otherwise, a bad ground could be the cause.
If it does come on, then suspect a bad relay (either contacts or coil). Does the relay click when the fan is turned on? If so, then perhaps there is a bad connection somewhere.
Old Dec 14, 2000 | 01:47 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Stuart has the right idea: wire the fan directly to the battery to make sure the motor is bad. That way you can isolate the motor, and rule out any other possible problems. But be sure to get a wiring diagram so you can figure out which of the terminals on the fan motor is positive and which is negative. Because if your fan motor is still good and you wire that sucker up backwards, well, lets just say it won't be good for very long.
Old Dec 14, 2000 | 01:52 PM
theformula's Avatar
ok. thanks for the helps guys
91 Formula
305 TPI 5speed
1LE/G92/WS6
Custom cold air intake w/K&N, SLP airfoil, ported plenum, TB coolant bypass,Crane AFPR (47psi),94 octane,Crane Extruded Alum. 1.6 full roller rockers, Timing set from 4*BTDC to 10*BTDC,MSD6AL, Holley 9mm Annihilator Laser shot 50 wires, Ac Delco cap,rotor and plugs, Bosch O2sensor, SLP 1 5/8 headers,SLP catback,3:73s,JET 195* fan switch, Macewen white face gauges, Intellitronix Digital Gauges
Old Dec 14, 2000 | 06:44 PM
88IROCARMY's Avatar
The fan motor runs $20-30 at a parts store. The dealership will want $90-100 a piece.
try the electronics message board, I just finished a fan battle and there are many fan war veterans there also. good Luck
Old Dec 14, 2000 | 07:02 PM
theformula's Avatar
lol fan war battle.
I've been having a lot of battles with this car latey.
91 Formula
305 TPI 5speed
1LE/G92/WS6
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
LittleFranks
Sep 17, 2015 12:22 PM
Street Lethal
Aug 14, 2015 08:25 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
