1985 IROC TPI 305....car runs like *** when its cold
Old Nov 2, 2003 | 06:07 PM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
Seems like the cold start part of my fuel injection on my TPI iroc doesn't work. When I first start the car on a cool day, it almost dies and barely runs, then backfires through the intake a couple times as you take off. Then when it warms up to about 160ish, it runs perfectly fine and doesn't exhibit any of these problems. Whats going on here??? No engine codes either.
Old Nov 2, 2003 | 08:43 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
your electronic choke if u have one took a dump?
Old Nov 4, 2003 | 12:28 AM
Car: Junk
there is electronic choke on TPI?
Old Nov 4, 2003 | 04:55 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
I don't know, hence why i had a question mark on the end of my sentence... A sticky choke causes those symptons but i don't know much about tpi...
Old Nov 4, 2003 | 08:03 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
umm i would say no choke as it is fuel injected. still has a choke function would have to. cold start injector has something to do with it and the comp controls the idle but i don;t know how off hand.....sorry i'm of little help
Old Nov 4, 2003 | 11:49 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
May be your cold start injector.
Old Nov 5, 2003 | 03:52 AM
Morley's Avatar
See my reply in this thread. https://www.thirdgen.org/techbb2/sho...hreadid=208578
Old Nov 5, 2003 | 07:47 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
You can rule out the choke since there's not one.
The cold start inj only works when the starter is being engaged, so you can rule that out too.
I'd check fuel press and for vacuum leaks. Sounds like you're running lean.
Vintageracer
Jan 10, 2020 05:33 PM
Wade787b
Sep 29, 2015 01:15 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
drathaar907
Aug 6, 2015 04:20 PM
