counterweight to block clearance
Old Nov 24, 2003 | 06:58 PM
redrummer's Avatar
Car: '88 Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27 Aussie 9 Bolt
What's the minimum clearance I can have between the block and the crank counterweights?
Reason I'm asking is because I just got my new Scat crank home and the rear counterweight hit the side of the block where the oil filter sits. I only had to grind the block down about 1/16" to allow the crank to spin freely. I've got just over .02" of clearance between the counterweight and the block. I can't go but probably another 1/8" before I get too close to the oil pan bolt hole.
Old Nov 24, 2003 | 07:04 PM
Damon's Avatar
I try to keep it at least .025" and I've never had anything collide with anything else at that clearance in a stroker bottom end. You're real close.
Old Nov 24, 2003 | 07:14 PM
redrummer's Avatar
Engine: 5.7L L98
I don't really have a good way to measure it right now, no feeler gauges in my arsenal or anything. I just used a cardboard cereal box top. The crank was sliding against it, but there was no pull or anything. I measured three times and got .020, .022, and .020 again. I just used this method to get a general idea where I was at.
So anything greater than .025" and I should be okay?
Old Nov 24, 2003 | 07:26 PM
redrummer's Avatar
Engine: 5.7L L98
I found a piece of steel stock that measures .045". It slides between the weight and block just fine except at one point where it hits and slightly catches. I'll grind that down a little more and test it again.
Old Nov 24, 2003 | 10:43 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Get a plastigage string and put it in the groove and swing the crank till it crushes it.
That will give you an accurate-ish number for about $0.50
Old Nov 25, 2003 | 04:37 AM
redrummer's Avatar
Engine: 5.7L L98
I thought about doing that, but I figured the weight would break the plastigage rather than squish it and I wouldn't be able to get a reading.
It's cool though, I got it ground down to where I could fit two of the .045" pieces of bar in there with a little wiggle room. I've got just over .09" of clearance.
Old Nov 25, 2003 | 04:42 AM
ede's Avatar
ede
i've used music wire crimped ina piece of steel tube for a gage. can't remember the diameter right now but it was close to .050, it was 2nd or 3rd string from a guitar.
Old Nov 25, 2003 | 07:33 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
The machine shop that built my shortblock told me to use 2 plastic wire ties together to check stroker crank clearance. Watch the big end of the rod & cam lobe clearance as well. The shop reccomended .050" clearance on the rotating assembly.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
92projectcamaro
Dec 8, 2015 12:25 AM
thunder57
Nov 7, 2015 02:28 PM
91 SrS
Oct 7, 2015 04:32 PM
skinny z
Oct 5, 2015 06:23 PM
