Pro Magnum rockers and centerbolt valve cover q...
Old Dec 2, 2003 | 10:37 AM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Is there any clearance issues wen using Comp Camps Pro Magnum non-self aligning rockers and center bolt valve covers? They arent narrow body rockers, so is it possible to clearance the valve covers enough for these to work?
Old Dec 2, 2003 | 12:24 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
I am running them with no probs. I am running tall valve covers but I believe you are concerned with the clearance around the centerbolt webbing in the valve cover not with height correct?
I had custom valve covers made and went tall just in case I ever needed them.
Maybe someone else running them with factory valve covers can chime in.
-Schultzy
Old Dec 2, 2003 | 12:34 PM
Oh i remember your valve covers alright... some of the most kick *** ones Ive ever seen!
Old Dec 2, 2003 | 12:44 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
i just "modded" my valve covers to work with the crane gold's i have.... narrow body def not necesary if your willing to modify
Old Dec 2, 2003 | 12:50 PM
jichniow's Avatar
Car: 89 IROC-Z
Engine: 6.0L LQ4
Transmission: 4l60e
Axle/Gears: 3.70
I'm running them with the stock valve covers. I had to cut all the webbing and oil baffles out. I tried the covers sold through Summit (SUM-G3314) but they wouldn't work either. Of course they told me they would fit my rockers and now the web page only lists the narrow ones.
But if you cut out the junk inside the valve cover you'll be fine. Dremel to the rescue.
Old Dec 2, 2003 | 01:05 PM
fb305svs's Avatar
only problem with do that on the stock valve covers is that the metal is thin and flexes too much to make a proper seal...
i picked up a set of pretty mint covers, they are cast aluminum, i used a porting bit to just take all the material out- fits perfect, and no leaks around the edges!
Old Dec 2, 2003 | 06:36 PM
jichniow's Avatar
Car: 89 IROC-Z
Engine: 6.0L LQ4
Transmission: 4l60e
Axle/Gears: 3.70
I had the exact opposite experience. The cast aluminum valve covers didn't have a lip on the bottom and wouldn't hold the gasket properly. They were a pain to get the gasket lined up correctly and then the they still leaked all over the place. But the stockers work perfect.
Old Dec 2, 2003 | 08:16 PM
fb305svs's Avatar
well, i got a goooood set tho, and they held the gasket perfect
MoJoe
Sep 24, 2015 09:12 PM
db057
Sep 4, 2015 07:57 AM
Thaney9
Aug 29, 2015 03:16 PM
LT1Formula
Aug 20, 2015 09:36 PM
mustangman65_79
Aug 8, 2015 01:18 AM
