Car Cranks...wont Start...heres What Ive Done...
Old Dec 31, 2003 | 04:25 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
Ok 1983 camaro...305 4bbl....stock HEI ignition
car cranks wont start
verified fuel delivery
held spark plug wire near header...cranked...no spark
replaced....ignition module...ignition rotor and ignition coil
ive checked all wires......and all connections..all are in good shape...
battery and alt are good....
simple system..yet im stumped
any hellp is greatly appreciated
Old Dec 31, 2003 | 04:46 PM
Morley's Avatar
Still no spark? Did you replace the module with an AC Delco? A lot of the aftermarket crap is bad right out of the box.
Old Dec 31, 2003 | 04:50 PM
Axle/Gears: 3:08
yep acdelco..im stumped 2
Old Dec 31, 2003 | 10:48 PM
Axle/Gears: 3:08
ttt...anone got any clue
Old Dec 31, 2003 | 11:55 PM
Morley's Avatar
Have you verified you have 12 V going TO the distributor?
Old Jan 1, 2004 | 12:45 AM
Vader's Avatar
Try disconnecting the EST connector in case the EST is killing the spark primary.
Old Jan 1, 2004 | 01:20 AM
Axle/Gears: 3:08
est connector...that would be...what...and no didnt verify voltage to distributor..btu battery is brand new..what would i have to check...im not totally new but not experienced as some of you guys..so any help would be appreciated no matter how basic
Old Jan 1, 2004 | 02:19 AM
Morley's Avatar
EST wire is the lone brown wire coming out of the loom on the firewall on the passenger side, it has a single pin connector on it. Disconnect it there to eliminate the EST.
To check voltage going to the dist, find the connector on the cap that is labeled "Batt", that is the 12 V input to the dist., check it for voltage to ground with the key on.
Old Jan 1, 2004 | 02:22 AM
Axle/Gears: 3:08
i just checked..dont see brown wire....or single connector on passenger side..what does est stand for...still have to check voltage but its 325 am so ill wait till morn..lol
Attached Thumbnails Car Cranks...wont Start...heres What Ive Done...-thirdgenpic.jpg
Old Jan 1, 2004 | 10:30 AM
Morley's Avatar
EST= Electronic spark timing (what the ECM uses to adjust timing)
But by the looks of that pic (if thats you & your car) then i doubt you have the computer controls any more...So, verify 12 V going TO the dist. If it has 12 V going in then it has to be one of the parts you already changed that was bad from the box.
One more thing, check the grounds from the engine to body, make sure they are there still and clean (under the connecting lugs too)
Old Jan 1, 2004 | 10:34 AM
Vader's Avatar
...And on an '83 or other CCC car, the EST connector is a four-wire, flat connector at the distributor.
Old Jan 1, 2004 | 06:07 PM
Axle/Gears: 3:08
yeah as you can see from the pic no computer controls...or computers for that matter...lol...i tried to keep it simple...im bettin it was just a bad part out of the box..cause their literally isnt much else to change..but i do need to verify voltage....
ill keep ya updated
Old Jan 1, 2004 | 06:56 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
simple is the way i like it and in my eyes, if theres a computer running the shot, then simple is far from reach lol...
if you find your 12 volt power is in fact dishing 12 volts, i would focus your attention back to your coil... the ignition module can be tested but have them test it a few times (to get it heated up) or use a blow dryer... but i think its your new coil =]
Old Jan 1, 2004 | 06:57 PM
Axle/Gears: 3:08
so you think that i may have replaced the bad coil with a bad coil...great...lol
Old Jan 1, 2004 | 11:37 PM
Morley's Avatar
Kinda hard to say. Have you checked out the rest of the dist? Reluctor ring, magnets, primary coil and all the connections inside the dist?
Old Jan 2, 2004 | 02:01 AM
Axle/Gears: 3:08
ok youve officially surpassed my level of expertise..i have a manual though so i will look into how do do that
Old Jan 2, 2004 | 05:33 PM
Morley's Avatar
Heh, ok. While you're at it, there is an Ohms check you can do on the ignition coil to see if maybe it is defective.
Old Jan 2, 2004 | 09:28 PM
1fastformula's Avatar
Car: 1989 Formula 350 / 2000 Lightning
Engine: GM HO 350 Crate (Vortec headed w/TPI) / SC 5.4 330
Transmission: Rebuilt 700R4 (Raptor Rebuild Kit)
just an observation......Did you put the grease on the module???? If not, it will short out instantly and be dead like the old one.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
