VATS, STARTER, or FUSIBLE LINK
Old Jan 24, 2001 | 01:51 PM
FRDH8R's Avatar
Alright, my car won't start. Turn the key, nothing, nothing at all. No cranking, nada. Battery seems to be fine, the fan will turn on with ease, and all lights work.
My question is, could this be just the starter? Or could it be ignition switch, vats, or fusible link to starter? Also, how could I bypass the vats?
thanks in advance.
My 91 RS
Nor-Cal Crew For Life
Old Jan 24, 2001 | 05:08 PM
Blue92's Avatar
Did you repair something before this started?
Because That will give everybody a starting point. Good Luck
Old Jan 24, 2001 | 05:39 PM
mostafa3k's Avatar
Jarrett, you still selling your car? I saw the ad on your webpage, and e-mailed you but you never responded.
Of curse this starting problem puts quite a damper on my hopes. ;o)
Old Jan 24, 2001 | 06:18 PM
ihateallmustangs's Avatar
take a look at your neutral safety switch.
Old Jan 24, 2001 | 07:30 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
For starters, (pardon the pun ) check and see if the starter is getting power on the signal wire when you turn the key to crank.
If you've got power down there, its the starter.
If you don't, it could be the VATS, n/safety switch, ignition switch, etc.
Ay least this way you know which direction to look.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Jan 24, 2001 | 08:32 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Could be something as simple as dirty wire terminals... happened to me. Every now and then it would just decide not to start. Last time it happened I reached up to the solenoid wires on the starter, gave 'em a little wiggle and varoom! I got it home, disconnected all starter and battery terminals and cleaned them up and haven't had a problem since...
KAM
Old Jan 25, 2001 | 02:52 PM
FRDH8R's Avatar
Well, sure enough, it was the starter. Got a $100 one and swapped it in, and boy does it start quick now. It used to take a while to crank, and then it would start. Now it starts right up.
As for selling the car, yes it is still for sale. Sorry for not responding, I've got about 100 messages in my inbox regarding it and still haven't gotten to many of the messages. As I speak today, I've agreed to sell it for $2900.
My 91 RS
gta892000
Aug 11, 2019 11:16 AM
gta892000
Sep 16, 2015 12:40 AM
gta892000
Sep 16, 2015 12:37 AM
64goatman
Sep 9, 2015 01:09 PM
383cam
Sep 9, 2015 06:01 AM
