White smoke on startup and idle?
Old Feb 15, 2004 | 10:23 PM
87GTAspeeder's Avatar
Car: 1987 GTA :)
Engine: duh! 5.7 TPI
Transmission: Stock
Hey, done lots of searches and now just kinda getting a better feel. It's an 87 GTA, and on startup it'll smoke out the exhaust (not too much) or if it's idled for a few minutes. Also if it's started to idle and I give it gas (ie in N or P). There's appears to be no coolant leak, and the oil looks ok. Will an oil analysis be worth it? What could the possibilities be? I would assume possible valve seals, head gasket, anything else? Thanks guys!!!
~Geoff
Old Feb 15, 2004 | 10:28 PM
caleb's Avatar
Car: 89' Iroc
just my $.02 i would say head gasket, white is generally coolant, bluish is oil!
Old Feb 15, 2004 | 11:18 PM
joshwilson3's Avatar
Old Feb 16, 2004 | 12:11 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Why don't you guys do a bloody compression and leakdown test for cripes sakes! I wish I had the energy you boys do! Ifin' you feel the need to do some head gaskets I have about three booked for april, come on down and I'll be glad to oblige!
Old Feb 16, 2004 | 12:12 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Originally posted by joshwilson3
With the heads off, is there any cleaning I can do to them and the valves and piston tops and cylinder walls? What type of cleaning can be done, and what products do you guys use?
I like to keep my heads on and use some water.
Old Feb 16, 2004 | 12:44 AM
Car: 1987 GTA :)
Transmission: Stock
lol, I'm gonna do the compression test and leakdown this week...just trying to get a feel once I'm beyond that. I'm nosey and want ideas while I wait lol. Thanks
Old Feb 16, 2004 | 12:53 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
You had me worried there a sec! Don't do that, I'm not young anymore dammit!
Old Feb 16, 2004 | 02:53 AM
Old Feb 16, 2004 | 04:09 AM
biff85ta's Avatar
Car: 04 Vette
Or it could just be that it is cold outside and there is moisture in the exhaust. Do you have cats?? If not it may not ever completely go away in the cold weather.
Old Feb 16, 2004 | 04:29 AM
Old Feb 16, 2004 | 07:32 PM
taman86's Avatar
Car: '86 TA 305 F, '89 GTA 8
Engine: F 305 TPI, 8 350 TPI
Transmission: 700 r4
whiyte smoke
I have got an '86 TA, and a '89 TA GTA. Both of them blew white smoke out the back, after I had sprayed Throttle-body cleaner down the
throttle, and into the plenum. They both smoked worse at start-up. On my GTA, I sprayed down 3 cans, and it blew out so much white smoke, that some lady called the fire department. It was kind-a dark, and she never saw no white car smoke before. I live in an apartment complex, and It totally saturated the air.
The GTA blew white smoke for quite awhile, Now both cars are fine.
Old Feb 17, 2004 | 09:01 AM
Z dude's Avatar
Car: 1991 Z-28
Engine: TPI
Transmission: 5-speed Rear:3.73
3 cans do you think that was enough
Old Feb 17, 2004 | 05:34 PM
TJQIROC's Avatar
Car: '16 Camaro SS, '88 IROC
Engine: 6.2 Gen V
Transmission: 6 spd TR6060
These engines are notorious for valve seals going bad. Its a tough job replacing but not that bad if you have the right tools. Cost is cheap, 16 valve seals and a couple of valve cover gaskets. If you do the compression check and that is OK, suspect the seals. I did mine a few years ago and haven't had smoke on startup ever since.
Old Feb 18, 2004 | 01:40 AM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
