Eveyone w/ Serpentine systems
Old Feb 15, 2001 | 12:49 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
I was hoping somebody could give me either the size specifications or the part #'s of the 4 bolts that bolt the passanger side sepntine bracket to the motor. This is the bracket that holds the a/c compressor, smog pump and tensioner. thanks a lot
SUPERCHARGED 87 GTA: Blk/Gld w/Superam, 355cid Trickflows, forged pistons 9.5:1. Auto 2,600 stall, 3.45 9 bolt disc, Best time & mph (Naturally Aspirated): 13.567 @ 101.900 w/ a poor 60ft. Best mph: 104.3 *This car is 100% NYS emissions legal, w/ all emissions controls!* "If you want to have a fast car, hang out w/ those who do!"
http:// www.community.webtv.net/munks87/JustinsGTApage.com
VORTECH S-TRIM, INSTALLATION IN PROGRESS: 10 & 15 LB> PULLEYS, CUSTOM HKS RACE BYPASS, CUSTOM DUCTING W/ COLD AIR, SWAPPING TO SERPENTINE, & MANY EXTRAS! BEST TIME: 11'S I GUESS. WE'LL SEE IN SPRING!
Old Feb 15, 2001 | 04:21 PM
Dana92RS's Avatar
Here's what I could tell from looking in my parts catalog:
2 bolts down at the bottom, p/n 14091547 (TORX 3/8-16X1 1/8)
1 stud p/n 10055883 (SECD AIR INJN PUMP & DRV BELT TENSR BRKT 9.52X69.85) with a nut p/n 14057004 (HEX FLANGE 3/8-16 PC 286M)
2 studs for the A/C compressor that in turn connects to 2 braces that connect to the block. Stud p/n 10055888 (A/C CMPR M10X1.5X110, 3/8-16X20) and both use nut p/n 14057004
The braces are p/n 10105267 (LWR) and 10105292 (UPR)
The end of the braces that go into the block use stud p/n 14057279 and nuts p/n 14057004 except L98/LB9 get bolt p/n 11508106 (HFH M8X1.25X25 9.8 POR) instead of one of the studs.
Other than that there is one bolt p/n 14089928 (M12X1.75X36) that bolts the A/C compressor to the bracket.
I included all the parts that the parts catalog showed, not just the bolts that you asked for. The stuff inside the parenthesis () are the part descriptions that the catalog gave for each part. Hope that helps.
Old Feb 15, 2001 | 06:15 PM
Guest
Guest
Posts: n/a
All the bolts for the bracket that thread into the head or block are standard thread, the 3/8-16 listed above. The bolts that thread into the bracket itself are metric.
Old Feb 15, 2001 | 08:25 PM
Car: 1987 GTA
yes, it helps a lot! thanks very much, I appreciate it. I got some other part #'s, but I guess they are wrong. 10105201 and 10105202. you don't happent o know what they are for do you? thanks -justin
[This message has been edited by Justin 87 GTA (edited February 15, 2001).]
Old Feb 16, 2001 | 08:20 AM
Dana92RS's Avatar
Oops, my bad! When I looked up that info, I just looked in the section for the A/C system and did not look at the smog pump setion. Both of those part numbers (10105201,10105202) are bolts that hold the smog pump to the bracket.
10105201 (BOLT, SECD AIR INJN PUMP (UPR) 3/8-16X5.90)
10105202 (BOLT, SECD AIR INJN PUMP (LWR) 3/8-16X3.75)
Old Feb 16, 2001 | 02:06 PM
Car: 1987 GTA
so they go through to the block? I have one that just goes into the bracket and the other one, i'm missing, it seems as if it goes throught to the block. which is which.? is there any way i can view these diagrams on-line.? thanks a lot, you've been very helpful.
[This message has been edited by Justin 87 GTA (edited February 16, 2001).]
Old Feb 16, 2001 | 03:23 PM
Dana92RS's Avatar
Here you go...
Page 3-92 smog pump diagram
Page 3-93 smog pump parts list
Page 9-26 A/C diagram
Page 9-27 A/C parts list
Sorry, they're kinda big files. I'll have to work on my scanning skills.
[This message has been edited by Dana92RS (edited February 16, 2001).]
Old Feb 17, 2001 | 03:14 PM
Omar's Avatar
Good pics, Dana. There are 4 bolts that hold the bracket. 2 upper ones in the head, and 2 lower ones in the block.
Upper:
Page 3-92, #8 10105202 Also holds Smog pump
Page 3-92, #6 and #7 - 10055883, 14057004
Lower:
Page 9-26, #7 14091547. 2 of these.
1989 IROC-Z 5.7L
[This message has been edited by Omar (edited February 19, 2001).]
Old Feb 18, 2001 | 11:36 PM
Car: 1987 GTA
that's excactly what I needed! thank you both very much.
[This message has been edited by Justin 87 GTA (edited February 18, 2001).]
Old Feb 19, 2001 | 11:01 AM
89FormulaRoth's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7L TPI
Axle/Gears: Borg Warner 3.27
Dana92RS-Where did you get that parts catalog?
'89 Firebird Formula-
K&N Air Filter, Holley Throttle Body Air Foil, Hotchkis Strut Tower Brace, Hotchkis Panhard Rod, Hotchkis Trailing Arms, Kenny Brown Subframe Connectors, GT Auto Assesories aero wing
Old Feb 19, 2001 | 11:26 PM
Dana92RS's Avatar
I posted all the info in this link.
Ultra mr me
Sep 27, 2013 11:30 PM
87firebird400
Theoretical and Street Racing
Oct 11, 2010 12:37 AM
CamarosRUS
Jul 30, 2004 06:55 PM
uidzer0_z28
Carburetors
Jun 13, 2002 01:29 PM
Chris305TBI
Nov 6, 2000 04:36 AM
