What the heck is this????
Old Mar 26, 2004 | 12:01 AM
DURTYBIRD's Avatar
Car: '99 HO Z28 / '03 Trailblazer
Found this underhood blowing air after driving the car home. Its an LG4 car that has had a 350 swapped into it. I have no clue as to what it is:
If it helps, its on the passenger side of the car up front tucked in the fender area.
Old Mar 26, 2004 | 11:32 AM
Dingley's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
its a really dark picture. but it looks like a relay to a headlight.... but then again, i can't see anything.
Old Mar 26, 2004 | 02:55 PM
DURTYBIRD's Avatar
No, there is a relay next to it. Its a tube and it was blowing air. I've circled it in red if that helps any.
Old Mar 26, 2004 | 03:29 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
One thing that would help us identify what it is is if you told us where it goes.
Old Mar 28, 2004 | 11:40 AM
Vader's Avatar
I've downloaded it, enlarged it, adjusted it, and generally PaintShopped the heck out of it, and I still can't see what you are describing. Can you get a brighter photo?
Old Mar 28, 2004 | 01:13 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
This help?
Old Mar 28, 2004 | 09:13 PM
DauntlessZ28's Avatar
Car: 1984 Z-28
Engine: L69
Transmission: 700-R4
if you've still got your smog pump, then it could be a hose that just never found a home. that's the only thing that I can think of that would be blowing out air. i have no idea why it would be all the way over there though
Old Mar 28, 2004 | 09:22 PM
DURTYBIRD's Avatar
I was just as confused as you folks were. LOL!
It a jumble of parts that came with the car, I found a flexible hose that looks like it attaches somewhere else...like it blows ON something...but I can't figure out what.
Oh well, it'll probably be pulled out anyway if I decide to proceed with my LT1 project.
Thanks anyway.
Old Mar 28, 2004 | 11:06 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
Look to me like a coolant overflow tank cooler
Old Mar 28, 2004 | 11:39 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
or possibly a vacuum control unit that runs vacuum to PCV, the charcoal can, and brakes. Mine is (was) on the firewall.... I ran vacuum off of the manifold for most of that stuff, so i really don't need it. if it is what I'm talking about, it says "rochester control products" around the top.
Old Mar 29, 2004 | 07:38 AM
DURTYBIRD's Avatar
Definitely not anything to do with vacuum. It was blowing air at hairdryer speeds.
The coolant overflow tank cooler comment has me thinking...Is that anything like blinker fluid??? j/k
I'll have to look into it.
Loudnproud86
Jul 14, 2016 12:59 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
DonW
Carburetors
Sep 23, 2015 08:04 PM
aharvel50
Sep 21, 2015 07:31 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
