Port/polish 416's
Old Apr 10, 2004 | 04:47 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
Port/polish 416's
I am just about to start a port/polish on a set of 416's that I got my hands on and plan to put onto the L03.
Any suggestions/words of wisdom/experience as to some areas on these heads which I should/shouldnt really touch etc.....
BTW...this is going to be my 1st experience with porting.
Thanks,
Dave
Old Apr 10, 2004 | 05:07 PM
vjo90RS8's Avatar
Car: 2002 Z28
http://www.sa-motorsports.com/diyport.htm
Old Apr 10, 2004 | 05:53 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Thanks VJO...ya thats a great article.....I saw that onelast week when I was sort of searching around.
does anyone have any expereince with the 416's as in trouble areas specific to those heads??
Thansk
Old Apr 10, 2004 | 06:09 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The heads they show in their illustrations are 416's.
Vader posted some port templates not too long ago. Look around for them.
Otherwise, stick to the advice given in the instructions and you won't have any problems.
Old Apr 10, 2004 | 07:35 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
lol...well if they are 416's great....thanks guys!
D
Old Apr 10, 2004 | 11:18 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Follow the link at the end of my sig.
Old Apr 11, 2004 | 06:22 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
gasket matching
Here is some work on my dart heads
Attached Thumbnails Port/polish 416's-motor-1.jpg
Old Apr 11, 2004 | 06:23 AM
Engine: 406
intake side
Attached Thumbnails Port/polish 416's-intake-ports-2.jpg
Old Apr 11, 2004 | 06:25 AM
Engine: 406
intake
Attached Thumbnails Port/polish 416's-intake1.jpg
Old Apr 11, 2004 | 07:07 PM
mikobu3's Avatar
just finished porting my 416 heads
took me about 20 hours to do , had all the tools for this job i also recomend buying the deluxe porting kit from standard abrasives , ver y easy with there kit , have fun
Old Apr 11, 2004 | 07:34 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
ya I started on things today.....just with some misc bits that I had kickign around....all I have got to say is 2 hrs into this I can tell its going to take a LLLLLOOOOONNNNNNGGGGGG time from what I can see...oh well atleast it gives me something to do instead of things around thehouse for thenext week or so...ha ha.
D
Old Apr 11, 2004 | 09:17 PM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
Yeah, it takes a while. I think it took me around 1/2 hour for every exhaust port and about 1.5-2 hrs for each intake. My heads are the machine shop right now getting cut for 1.94 intake valves, 3-angle valve job & milling a tad. I cant wait to get them on the car
Along with SittingBulls threads, here is another thread with some good pics:
https://www.thirdgen.org/techbb2/sho...hreadid=211826
Old Apr 13, 2004 | 01:51 PM
five7kid's Avatar
I'd recommend getting a couple of carbide burrs as well, like a 1/4" ball and "Christmas tree". A long stem tree would be helpful in some areas as well.
I practiced on one cylinder of an 081, then went to work on the Worlds. I spent 10 hours getting both heads done (it seemed to take less to clean up the Worlds than it did the factory head). Grinding dust everywhere. I sure hope you're following their recommendations about goggles, dust masks, hearing protection, and gloves.
Old Apr 13, 2004 | 09:30 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Hey guys I was wondering about how much flow do you think you gain on these heads just from a 3 angle valve job and adding the 1.94 and 1.5 valves on these heads? I was just wondering because I am trying to compare my set of 416's to a set of numbers I saw on one of those links. Oh and sorry I am not trying to high jack this thread.
Old Apr 13, 2004 | 11:30 PM
Engine: 305-4v
That would basically turn them into a set of L98 350 heads. They flow a little better than 416s but the port and polish job is where the big flow numbers come from. People are getting Vortec flow from a good port and polish.
Old Apr 14, 2004 | 01:12 PM
mikobu3's Avatar
i will let you guys no in a bit , i ported and polished my 416's they look great , just got them back from the machine shop where they enlarged 1.94 seats and did a 3 angle valve job , they look great i can;t wait till the mechanic puts them in the car
also if your doing this job put in new valves ,springs, reatainers .ect , no point using old stuff
Dewey316
Feb 25, 2003 08:36 PM
pskel350
Nov 17, 2002 06:41 PM
radiateu2
Oct 30, 2002 04:31 PM
Garett92Z
Dec 22, 2001 11:18 PM
Mike-88CamaroTBI
Nov 2, 2000 08:06 PM
