Valve spring question
Old Apr 12, 2004 | 08:08 PM
Formula305FI's Avatar
Car: 96 SS, 88 IROC
Engine: Lt1, TPI
Transmission: m6,a4
Axle/Gears: 3.90. 3.73
Hey guys the max lift i am going to be running is .564 max..... are these springs any good?
Spring Pressure Installed: 135# @ 1.750" -- 115# @ 1.800"
Spring Pressure Open: 335# @ 1.250 -- 360# @ 1.200
Coil bind @ 1.170"
Old Apr 12, 2004 | 09:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If set up exactly perfectly, they will just barely barely be enough. A very small error, and you'll wipe cam lobes.
I hope you really trust your head guy.
Old Apr 12, 2004 | 09:03 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Im assuming this is a Hydra-roller cam like in your sig?
Car: 96 SS, 88 IROC
Engine: Lt1, TPI
Transmission: m6,a4
its roller cam, i didnt know they can be wiped like a flat tappet, can u recommend a nice affordable spring?
Old Apr 12, 2004 | 09:07 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
If its the 282hr cam likein your sig, why done you run the springs Comp recommends. THe 986-16's or the 987-16's. The 987's would seem, to me at least, to be the more preferable spring.
Old Apr 12, 2004 | 09:10 PM
Car: 96 SS, 88 IROC
Engine: Lt1, TPI
Transmission: m6,a4
i didnt know what springs to run with it. i got the cam off a friend for 100$ but this is kinda a budget build and really cant afford nice springs... so thats why i was looking at the z28's..
Old Apr 12, 2004 | 09:18 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
is the cam in the engine? Is it possible to look at the rear of the cam, on the rear face, by the distributor gear? You will see the grind info there.
Old Apr 12, 2004 | 09:20 PM
Car: 96 SS, 88 IROC
Engine: Lt1, TPI
Transmission: m6,a4
its in the engine... the head guy is very good, alot of people recommend him... and alot of the fl-thirdgen members are telling me not to worry the springs will be fine....
Old Apr 12, 2004 | 09:21 PM
Car: 96 SS, 88 IROC
Engine: Lt1, TPI
Transmission: m6,a4
i know its the hr282xr i called to varify with comp cams
Old Apr 12, 2004 | 09:23 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Then either of the springs i listed above are the ones recommended by Comp.
gta90
Sep 15, 2015 04:00 PM
crazynights
Aug 21, 2015 06:53 AM
redmaroz
Aug 16, 2015 11:40 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
