Cam question
Old Apr 24, 2004 | 04:41 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Cam question
dot to dot equal to TDC?
Old Apr 24, 2004 | 05:13 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
dot to dot is 180 out.
Old Apr 24, 2004 | 05:52 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
dot to dot = #1 & #6 TDC but not #1 firing; the instance of #1 TDC where the #1 exhaust is just closing and the #1 intake is just opening; also #6 TDC and #6 firing
both dots at 12:00 = #1 & #6 TDC; #1 firing and #6 valves rocking
Old Apr 24, 2004 | 11:52 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Heres my problem. The car was all put togehter timing and everything and everything ran. Well the timing chain was hitting the new cheap chrome cover so I took the chain off to inspect and said ehh damnit what to do now. I lined it up dot to dot. I shoudl have to mess with timing since the dis was in and never moved. right?
Old Apr 25, 2004 | 12:02 AM
Morley's Avatar
I would still put a light on it and check the timing..just to be sure.
Old Apr 25, 2004 | 12:43 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Unless its 180 off. Then it wont start. IN which case, you will have to bump the engine over to #1 TDC. Check the valves. If both valves are partially open, bump the distributor to #6.
Im pretty sure thats how it goes. Its late, im tired, im hungry, and i cant think straight.
Old Apr 25, 2004 | 01:32 AM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
Without degreeing the cam, dot-to-dot is the correct way to install your camshaft. So if you installed it that way, with some degree of precision, your cam timing is correct.
Now ignition timing is another story, and it never hurts to break out the timing light and check.
If the timing is right, that will serve as a check for your valve-timing because you never removed the camshaft.
Old Apr 25, 2004 | 06:47 AM
ede's Avatar
ede
dot to dot is the way to do the install so you can see and line things up easy. when it comes to sitting the timing you need to have both dots straight up and #1 at TDC for it to be timed to fire on #1 and then install the distributor with the rotor pointing to the #1 post on the cap.
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
