Unplugged line?
Old May 26, 2004 | 07:08 PM
germ83's Avatar
Car: 1984 Z28
Engine: 305ci
Unplugged line?
I have a metal line that is running on the passenger side of the car, right next to the exaust manifold. It is unplugged and i am not sure what plugs into it. Any ideas?
Old May 31, 2004 | 09:46 AM
Vader's Avatar
"Unplugged?"
There are several possibilities. It could be a fuel vapor return line, an air injection line to the cat converter, an air conditioner line, or an air injection line to the exhaust manifold. Can you follow the line until it connects to something? That should determine its purpose.
Old May 31, 2004 | 10:39 AM
88fbird's Avatar
Car: 84 S-10:(
A picture would help alot here.
Old May 31, 2004 | 11:24 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If it's the line I'm thinking of, it is the line that went from the Air Injection Reaction (A.I.R.) tubes on the exhaust manifold to the catalytic converter. See pictures.
Old May 31, 2004 | 11:25 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 2
Old May 31, 2004 | 06:52 PM
germ83's Avatar
Car: 1984 Z28
Engine: 305ci
I will snap a pic today after work if i can remember.
Old Jun 2, 2004 | 03:57 PM
germ83's Avatar
Car: 1984 Z28
Engine: 305ci
Old Jun 2, 2004 | 03:58 PM
germ83's Avatar
Car: 1984 Z28
Engine: 305ci
If yo ucan see it... insite the yellow circle. Tickster, got any ideas?
Old Jun 2, 2004 | 04:01 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'm betting that's not metal but hard plastic, and that it goes down to the EFE valve at the end of the exhaust manifold.
You probably have a female rubber plug laying hidden somewhere in that snake pit.
Old Jun 2, 2004 | 05:17 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I agree with five7kid, it could also go to the EGR solenoid if equipped with it.
Old Jun 2, 2004 | 05:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's metal, and goes to the heat riser (EFE) valve, which is in a little spacer looking thing between the exhaust manifold and the exhaust pipe.
It's supposed to get vacuum from a thermal vacuum switch; IIRC it's on the water outlet.
Old Jun 2, 2004 | 07:10 PM
five7kid's Avatar
If it's metal, I'll believe you. Mine's been gone for 2-1/2 years now, but as I recalled it was a sleeved plastic.
Memory's the 2nd thing to go, they say.
What was the 1st, again???
Old Jun 2, 2004 | 08:13 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Ask your wife. She might remember .... if she isn't getting too old too.
db057
Apr 28, 2019 07:45 AM
BumpaD82
Feb 26, 2016 02:57 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
earlpote
Sep 12, 2015 11:55 AM
pacoelrapido
Sep 11, 2015 02:41 PM
