Just finished FIRST engine build...YAY
Old Jun 5, 2004 | 08:48 PM
supermaxxbasher's Avatar
Car: 89 camaro RS
Engine: soon to be juiced built 357
Transmission: turbo 350
Hey guys I just finished my first engine build...here are the parts I used... Stock 4 bolt non roller block with Hyper pistons, 10.3:1 compression, Edelbrock Performer RPM aluminum heads, Edelbrock Performer RPM intake, Comp cams 274* extreme energy cam, Comp cams 1.6r Magnum rockers, Holley 700cfm double pumper carb,Hedman long tube headers with true duals into dynomax super turbo mufflers,MSD 6 ignition box, MSD8.5mm wires, accel distributor with super coil...
Driveline.....Turbo 350 built for street strip, 2800 rpm stall convertor and 3.42 rear gear
I cant wait to fire her up and break it in...
Can anyone take a guess what kinda numbers I will put down with this combo???
Old Jun 5, 2004 | 09:51 PM
smithtc's Avatar
Congrats!
:yourock:
Old Jun 5, 2004 | 10:02 PM
Car: 89 camaro RS
all my problems are associated with the adjusting of the rockers...I cant figure it out...AAAHHH
Old Jun 6, 2004 | 07:31 AM
ede's Avatar
ede
Old Jun 7, 2004 | 05:16 AM
Car: 89 camaro RS
Does anyone have any guessing about my horsepower numbers??? I think i got the rockers straighten out.
Old Jun 7, 2004 | 06:53 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
I would think it should be good for at least 350 hp at the flywheel. Perhaps a fair bit more.
Old Jun 7, 2004 | 10:37 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I have a question. No flame intended but what made you chose hyper pistons over forged?
I'd HOPE you make more than 350HP because if you don't you just wasted a lot of money because theres guy with heads that cost a fraction of those Edelbrock RPM's with the same cam making around 450HP @ the flywheel.
Old Jun 7, 2004 | 11:04 AM
OMINOUS_87's Avatar
425ish if you get it dialed in **** on.
However all the guesses at power mean jack squat. The only thing that matters is mph at the track.
Old Jun 7, 2004 | 11:50 AM
Car: 89 camaro RS
The reason I used hyper pistons was I had the block machined by this guy and he recommended these pistons for me so we will see how they hold up..I am hoping for around 400hp out of this setup.
Old Jun 8, 2004 | 10:58 AM
Car: 89 camaro RS
Well I went to start the car for the first time today and BOOM flames shoot out of the carb....what is wrong? Timing?
Old Jun 8, 2004 | 11:04 AM
ede's Avatar
ede
timing, firing when the intake valve is open
Old Jun 8, 2004 | 12:27 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
CONGRATS!
my car has been sitting for over a year while i swapped on new heads/cam/intake/headers
i'm hoping the startup goes well.
Old Jun 8, 2004 | 01:45 PM
Car: 89 camaro RS
Alright should i advance or retard the timing??? So far the start up is not going good at all and I am afraid that I might ruin a cam by doing this?? is there anything I can do NOW to prevent a cam going bad?
Old Jun 8, 2004 | 01:54 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
More then likely you are 180* out. Thats pretty much the only way you can be firing the plugs when the intake is open, unless the timing is really retarded.
Bring the #1 cylinder to tdc on the compression stroke and restab the distributor back in with the rotor pointing at the #1 plug.
Old Jun 8, 2004 | 09:06 PM
Car: 89 camaro RS
woohoo car went through the 30 minute break in with a breeze...THANKS GOSH....Ok Where should I set the timing at with my setup???
Old Jun 9, 2004 | 02:09 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I'm not trying to flame but you built the motor and can't do rocker arms or set timing?
Somebody help you out or anything?
Old Jun 9, 2004 | 04:04 AM
Car: 89 camaro RS
Nope no one helped me out on this. Other than rocker arms and timing the rest is cake. As of now the car is running sound BUT I was just asking where the optimal timing is for this cam and motor. I want to set it for best performance and I was just asking what degee advance this cam likes but still maintain pump gas freindly.
Old Jun 9, 2004 | 04:23 AM
ede's Avatar
ede
every engine and combo is differant. you'd need to play around with the timing to find the ideal setting. as a rule you'll want 34 to 36 degrees total advance.
Old Jun 9, 2004 | 01:18 PM
Car: 89 camaro RS
ALright thanks guys
Cleotiz
Jan 6, 2018 08:56 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
InfinityShade
Aug 22, 2015 08:00 PM
Linson
Aug 21, 2015 02:12 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
