Possible to run a temp readout from the IAT sensor?
Old Apr 10, 2001 | 08:04 PM
Jester's Avatar
I wanna keep tabs on my air intake temp. I have no ECM or anything, so a scanner won't do it. Is there a reasonably simple way to do this other than just connecting an ohmmeter and trying to figure out what temp it corrisponds to?? How high a temp is the sensor good till (it'll be a boosted application)?
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
[This message has been edited by Jester (edited April 10, 2001).]
Old Apr 10, 2001 | 09:21 PM
JPrevost's Avatar
Car: 91 Red Sled
get a multimeter and an extra sensor
Chiltons has the readout/temp table
, Jon (350 TBI! getting 23mpg highway)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)AIM: JPrevost
  • Holley 670 TB unit w/ 1/2" spacer/adapter
  • Edelbrock RPM vortec intake
  • 350ho 330hp vortec crate motor
  • 8" harm. balancer
  • Stewart stage 2 water pump w/160 thermo
  • SLP tri-y headers to full 3"
  • Rebuilt trans w/ SLP shift kit
  • Centerline 16x8's all around
  • 36/24 mm sway bars
  • Full poly bushings, even motor mounts
  • SLP LCA and panhard
  • Alston SFCs
  • Edelbrock 3 point STB
  • Global west steering brace aka wonderbar
  • Eibach pro kit springs
  • Bilstien high perf. struts and shocks
  • All this and I still have AC
My websiteAny questions?
Old Apr 10, 2001 | 11:59 PM
Vader's Avatar
Jester,
Buy a new car with an outdoor air temperature display, compass, fuel calculator and all that junk. The "thermometer" uses the intake air temperature input as it's signal source.
You could do it with a DA converter and digital display driver, or connect an analog meter to the ignition source and calibrate the meter for the IAT voltage:
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old Apr 11, 2001 | 07:32 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Jegs sells an ultragage air temp guage 280-A024E061N
You will need the sender also 280-SENSS7E
It's red digital readout/black bezel 2 1/16" diameter and reads between -25F to 150F
If you think you will reach over 150F Summit sells Intellitronix "car stereo amplifier temp guage" that i'm sure will be easily adapted by finding a suitable location for the sender. (Possibly drilling or tapping a hole in the bottom of the plenum)
Good luck with your mission if you choose to accept (this message hopefully will self destruct in 5 seconds)
Old Apr 11, 2001 | 07:50 PM
Jester's Avatar
Thanks much y'all.
Old Apr 12, 2001 | 04:22 AM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
Jester!! Hey man how goes it? Haven't talked to you in FOREVER. I don't have ICQ anymore, if ya have MSN messenger gimmie your address.
Old Apr 12, 2001 | 04:23 AM
Car: Junk
Is Pablo still around? Are you still kicking his *** ?? ha hahah j/k Pablo
Old Apr 12, 2001 | 07:50 AM
Jester's Avatar
I havnt' raced Pablo in months...but I won the last time
Git back on ICQ dude! MSN sucks a$$!!
JSP Motorsports
ICON Motorsports
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
Logan Bryant
Aug 27, 2015 11:52 AM
bamaboy0323
Aug 15, 2015 07:20 AM
squiggy2
Aug 9, 2015 09:30 PM
