Turn Signals not blinking
Old Jul 9, 2004 | 04:38 PM
<<K-O>>'s Avatar
Car: 88 TransAM GTA
Engine: 305 LB9
Axle/Gears: Stock
My turn signals do not blink when use them they just stay open until I close them is this normal behaviour of my car or something wrong with my turn signals? Both front and back lights don't blink.
Any Idea what can cause this?
Also when push rear window defroster button all electrical systems go crazy in the car and sometimes engine stops what could cause this?
Thanks in Advance
Old Jul 9, 2004 | 05:30 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
For the blinker, you might need to refill hte blinker fluid reservoir - j/k. The relay might be broken and need replacement. For the defroster issue, see if the wirign is still intact, as having bare wires touching themselves will do nasty things. Check your assosiated (sp) grounds for the defroster too.
Old Jul 9, 2004 | 05:48 PM
<<K-O>>'s Avatar
Car: 88 TransAM GTA
Engine: 305 LB9
Axle/Gears: Stock
"blinker fluid reservoir" where is it and what do I fill it with? Sorry I'm a newbie at this.
Old Jul 9, 2004 | 06:05 PM
DJXero's Avatar
Car: 1992 Camaro Z28
He was joking lol. There should be a relay under your dash that is for the blinker, I think it's near the fusebox, if not attached to it. Sorry I don't have a pic to post, but i'm sure someone around here does. Or you can to go the auto shop, but a relay for it, and getb under the dash and play the matching game lol.
Or you can check here, sounds like he had a similar problem
https://www.thirdgen.org/techbb2/sho...hreadid=230031
Old Jul 9, 2004 | 06:13 PM
<<K-O>>'s Avatar
Car: 88 TransAM GTA
Engine: 305 LB9
Axle/Gears: Stock
Thanks for the answers I read the other post and I don't think I'll be able to fix it myself.
I'll take my car to a shop soon hopefully it will be fixed there.
Old Jul 9, 2004 | 09:33 PM
CaysE's Avatar
Ahahahaha! That's great!
Old Jul 9, 2004 | 10:02 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Turn Signals not blinking
Thanks in Advance
There is a Flasher relay located in the botom of the instrument pannel. Just go to a Auto Parts store and ask for a Flasher relay
and check with them were it is located.
Old Jul 10, 2004 | 02:13 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Possibly burned out bulbs or bad sockets.
Pull your hazards flasher on, and check to see if all the exterior bulbs flash - front ones beside the headlights, those in the front fenders, and those in the tailights.
Replace any that don't work, and check the turn signals again.
For the defroster problem, check and clean all your battery cables and ground connections.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
