colder spark plugs ok?
Old Jul 10, 2004 | 12:54 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i put 2stage colder spark plugs in my engine? is that gonna hinder performance any? thanks
Old Jul 10, 2004 | 01:00 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Why? At 15.6, probably not, but it may screw with your mpg., and emissions.
Old Jul 10, 2004 | 01:17 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i put them in cuz i had them laying around and i needed new plugs.
they are bosch platinums of that makes a difference.
Old Jul 10, 2004 | 06:13 AM
ede's Avatar
ede
you need some regular old fashioned AC delcos you aren't helping anything with the platinum plugs
Old Jul 10, 2004 | 06:59 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
ede, they are not that bad if you don't want to change your plugs for a while. So long as you don't blow money on the +4's. The only 'bad' thing about them is the slight taxing of the ignition system (as compared to a copper core) and the bad combination with a multi-spark unit. In a stock application for extended duty, they are pretty good.
Old Jul 10, 2004 | 07:43 AM
ede's Avatar
ede
i'll stick with ACs if i want anything a little extra i use rapid fires. now if i had something like a 305 monza (remember them) that had a 4 hour flat rate on plug R&R i'd use a high dollar plug that lasted 100,000 miles.
Old Jul 10, 2004 | 07:54 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Do I have to admit it if I do?
Old Jul 10, 2004 | 11:42 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
whats the big deal? all i saying is they have been sitting at my house for about 3 months, unused, so i just popped them in since i needed a plug change... except they were two stages colder then what i needed.
im just making sure my engine isnt gonna blow up or anything lol
Old Jul 10, 2004 | 12:16 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Yup. it's going to crack in half, lose half of the cylinders, get lypo-engine-suction, lose another half of that displacement and become a Civic engine.
Old Jul 10, 2004 | 04:36 PM
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
LOL! Make sure you get a video of it doing that!!!!
It'll hurt the mpgs and the power a bit. If you have them in there for long enough, you would be better of finacially going and getting the right ones. The wasted fuel will add up to the cost a new set of the right plugs very quickly.
Si.
Old Jul 10, 2004 | 05:10 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
THERE IS NO END TO MY HATRED FOR THOSE PLUGS!!!
They caused lots of carbon tracking and *** knows how much money in lost fuel because the threads on the damn terminals would crud up and the resistance would block current and cause a weak spark. Throw them in the trash and get the standard AC Delco plug for your application. If anything theyll slow you down over time.
Old Jul 10, 2004 | 05:21 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
A colder plug heat range will not in itself hurt anything. A colder plug runs cooler. which means it will tend to not
overheat and glow ( causing preignition) when you are WOT and making lots power. (heat)
Diuring normal driving A colder plug will tend to run darker an accumulate more deposits from low speed stop and go city driving and could have a shorter usefull life if that the way your car is usually driven.
Frequent short trips will tend to foul a cold plug faster than a hot(er) plug. Cause your not making enough combustion heat to clean the plug.
If you're a "lead foot" you got nothing to worry about.
A slightly colder plug will *help* keep the motor out of harmfull preignition while you're leadfooting it and will self clean the plug from a good hard run.
It's all a matter of heat management.
City driving- short trips = hotter plug
WOT hard driving- racing = select a colder plug heat range.
two steps colder is not going to be a problem.
Old Jul 10, 2004 | 09:21 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
thanks man, mainly i use my car to hotrod to work and back thats about it lol.. to broke to do anything else.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
